weird engine breaking sound when let off gas on highway
I noticed 2 days ago on the highway when i let off the throttle the motor makes a engine breaking noise( just like a semi engine brake) but it only does it on the highway. I'm baffled I don't even know what would cause this. Any ideas on where to start. Just did a tune up today, still makes engine brake sound
Do you get a sort or shuffle feeling when it does it? Like its going in and out of engine brake? Is it actually as loud as a semi trucks jake brake? Mine did it at certain RPM's when my tps was bad. Try checking that, if its in spec, try the whole circuit from the computer to the plug, or even just unplug your tps and drive down the highway and see if it fixes it. If you have a carburetor, you may have a vacuum leak, or your dashpot could be out of adjustment not allowing the throttle to fully close allowing the engine to properly lean out when you let off the throttle. Dashpot is for efi and carburetor engines on these trucks. Sorry for the log response, but you didn't specify if you have a carb or efi engine.
Sounds like dashpot failure: http://personal.utulsa.edu/~nathan-b...93throttle.pdf
skoti89
Jul 6, 2015 07:45 PM
Jnkml
Jul 6, 2015 01:20 PM
