Crawler + Auto tranny?
So, when someone puts in a second transfercase (on an older 1st or 2nd gen), does it typically go after the stock transfercase, or in between the transmisson and the stock t-case?
In the case of a truck or 4Runner with a gear driven t-case, the second case is usually added after the existing one. Unless both are the same in which case it doesn't matter. In the case of automatics or chain driven cases, the existing case is discarded and two gear-driven cases are installed in its place. This setup requires two adapters, one after the transmission and one between the cases. There is a third possibility and that is the addition of a complete gear-driven case with the OTT divorced adapter behind any other case.
Originally Posted by jruz
I've read somewhere that if you go too low with the auto + crawler...you won't be able to stop.
You'd have to pop it in neutral/park so you can stop moving.
(might be an old wives-tale though...)
Jim
Jim
Hey Joe!
BTW thanks for the axles! They're great spares......
Hows your ride doing? I like the way Marlin installed the Twin Stick assy. When I was at his shop last December, he showed me how to do it. I ended up getting a crawl box before I left
Easy.
On the new trucks it should be an MC09.
Marlin has an adaptor to get a gear drive t-case behind the A340F, then just another dual case adaptor to get another gear drive case.
Purely by the numbers, a dual Ultimate A340F will be at 158.8:1 but that does not count a factor of 2 for the torque convertor.
On the old junk, you have to use a new tranny to get a separate tranny and t-case. At that point, you are half way to a 3.4 swap which sounds like a good idea.
If I had a new truck and was intent on wheeling it, I would sure wait on the crawler until the axle swap so I could use gear drive cases and passenger side outputs.
Originally Posted by Joe
There's a few manual 5 speeds around that won't stop (kill the engine) in "Grandma" but I have no problem what-so-ever in 1st gear, low range and crawler engaged (308:1 figuring in the torque converter) in the Tundra.
Originally Posted by BruceTS
Hey Joe!
Originally Posted by Mad Chemist
So... you can have a dual T-case setup with an auto, assuming you can get the proper adaptors. I'm specifically wondering about a 2nd gen. 3.0 automatic.
okay... never mind:
http://4x4wire.com/toyota/tech/autocrawler/
phil johnson was #1... i'm #2...
Jim
Jim
Jun 1, 2021 01:51 PM
tinigunner11
Aug 14, 2015 01:19 PM
Iceman4193
Jul 15, 2015 04:48 PM
