81 22r into an 87 HELP!
Old Mar 19, 2013 | 04:17 PM
kawasakilewis's Avatar
i have an 87 truck and there is oil coming out of all over and my timing coverbis cracked. i have an 81 motor that is just sittin covered up, i was wondering what are all the major differnces? will it be a straight motor swap? is it bolt up and/or plug and play? any input wouod help please?
Old Mar 19, 2013 | 04:33 PM
yodafan93's Avatar
why not just change a few gaskets and change the timing cover?... not that expensive or hard..
Old Mar 19, 2013 | 04:36 PM
because i have tried everything i know to get the crankshaft bolt out and it will not come out, a brand new 600ft lb torque ingersol impact wouldnt even take it out. and almoat every gasket is leakingon the front. the old 22r i have would be dual row timing chain amd doesnt have any leaks or anything.
Old Mar 20, 2013 | 06:36 AM
Yamiryder's Avatar
i think it time for a 350 swap. you truck a turd. it also a mall crawler.
Old Mar 21, 2013 | 08:52 PM
yodafan93's Avatar
you cant get the crankshaft bolt out? what all have you done? penetrating oil every 30 mins for a day, and a torch to the bolt to heat it up, then try torquing the crap out of it while its hot. maybe knock on it with a few taps with a hammer. ive gotten alot of stuck bolts out that way. i didnt have to go quite that far with my crankshaft bolt. be sure the motor is locked somehow. and go at it.. ive heard of people using a bump stop method, where they take a wrench and wedge it on the bolt and use a breaker bar to stop it at the frame, then they hit the starter one quick time and it usually breaks free.. but i feel thats kinda dangerous.
Old Mar 21, 2013 | 09:21 PM
dropzone's Avatar
Fossilized
plugs will be different
Old Mar 22, 2013 | 02:50 AM
Co_94_PU's Avatar
Take the hood off so you can get an proper sized cheater bar in there. There should be some pics floating around of a DIY SST to hold the pully, it's basicly a bar a pin a thru hole and another pin. Sorry no links IR lazy.
If you break it you'll have more incentive for the swap yeah?
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
