Where does this plug go? 1993 22re
Old Jan 9, 2013 | 12:10 PM
VAhunter's Avatar
Took of the intake and put it back on, no engine won't crank. Found a gas leak but it should still try to start, right? Anyways I also found this stray plug hanging down, any idea where it goes? I hangs down on the passenger side of the motor near the starter
Attached Thumbnails Where does this plug go? 1993 22re-image-1628566329.jpg   Where does this plug go? 1993 22re-image-668374822.jpg
Old Jan 9, 2013 | 03:40 PM
Bigblock's Avatar
OP sender?Starter?Knock sensor?Fuel Injector?
Old Jan 9, 2013 | 04:07 PM
VAhunter's Avatar
All of the injectors are plugged up, knock sensor uses a different plug, gonna check the starter later, I got mad at it and had to go to class for the night
Old Jan 9, 2013 | 04:41 PM
Tim Steele's Avatar
Looks like the starter signal wire
Old Jan 9, 2013 | 04:48 PM
VAhunter's Avatar
Would that cause nothing to happen would I turn the key?
Old Jan 9, 2013 | 04:53 PM
Tim Steele's Avatar
Yea there should be a place for it to clip in on your starter. When you turn the key that wire signals the starter to turn over.
Old Jan 9, 2013 | 05:26 PM
slacker's Avatar
yep .. starter sig wire
Old Jan 9, 2013 | 05:42 PM
VAhunter's Avatar
Awesome, thanks guys...now to fix the fuel line. Yay
Charecter1
Nov 6, 2023 10:08 AM
MO transplant
Apr 23, 2023 11:58 AM
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
bryan34w
Jul 6, 2015 05:53 PM
