??3.4 swap from 95 t100 to 91 4runner wiring
so i have almost finished my 3.4 swap and i plugged everything in to try to start the 4runner and nothing happens no check engine light or nothing here is what i have wired up
the donor is a 95 t100 2wd auto
its goin in to a 91 4runner 5speed
i turn the key onto the on position and nothing happends no check engine light or hear the fuel pump kick on or nothing so i turn the motor with a starter trigger bypass and the motor just turns.
can somebody help me figure this out
oil ih2 #11 to ie1 # 10
coolant temp ih2 #14 to ie2 # 18
tach ih2 #20 to ie2 # 12
the W wire ih1 # 3 to ie1 # 18
B+ wires from ih1 # 16 to E4a # 22 and IE1 # 9
BATT ih1 #10 to E4 a # 14
FC ih1 #23 to ie1 # 16
IG2 ih1 # 14 to Ie1 #14
stop to brake ih1 #5 to E4a #25
Ac ih2 # 15 to ie2 #11
TC ih1 # 9 to ie1 # 6
i have not wired up spd or st1
i dont plan on wiring up and of the 4wd stuff since i dont have add anymore
can someone double check if i had done the adapter harness right ??
or am i missing something
any help would be awesome
https://www.yotatech.com/forums/f160...-101-a-239002/ Look over the COR wiring really good.
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
Sep 22, 2015 07:25 PM
