??3.4 swap from 95 t100 to 91 4runner wiring
so i have almost finished my 3.4 swap and i plugged everything in to try to start the 4runner and nothing happens no check engine light or nothing here is what i have wired up
the donor is a 95 t100 2wd auto its goin in to a 91 4runner 5speed i turn the key onto the on position and nothing happends no check engine light or hear the fuel pump kick on or nothing so i turn the motor with a starter trigger bypass and the motor just turns. can somebody help me figure this out oil ih2 #11 to ie1 # 10 coolant temp ih2 #14 to ie2 # 18 tach ih2 #20 to ie2 # 12 the W wire ih1 # 3 to ie1 # 18 B+ wires from ih1 # 16 to E4a # 22 and IE1 # 9 BATT ih1 #10 to E4 a # 14 FC ih1 #23 to ie1 # 16 IG2 ih1 # 14 to Ie1 #14 stop to brake ih1 #5 to E4a #25 Ac ih2 # 15 to ie2 #11 TC ih1 # 9 to ie1 # 6 i have not wired up spd or st1 i dont plan on wiring up and of the 4wd stuff since i dont have add anymore can someone double check if i had done the adapter harness right ?? or am i missing something any help would be awesome |
https://sphotos-a.xx.fbcdn.net/hphot...18675392_n.jpg
newer seat in to the 4runner https://sphotos-a.xx.fbcdn.net/hphot...93992348_n.jpg engine in the truck https://sphotos-a.xx.fbcdn.net/hphot...00503411_n.jpg overall https://sphotos-b.xx.fbcdn.net/hphot...38508571_n.jpg |
https://www.yotatech.com/forums/f160...-101-a-239002/ Look over the COR wiring really good.
Originally Posted by vasinvictor
(Post 52015037)
isnt the cor wiring say from the ecm wire the FC to the g-y wire which is the same as the ih1 #23???
