1987 Pickup not running right
I picked up this 1987 pickup 2 days ago and am trying to find out why it is not running right. It will only start when using starting fluid and will not hold an idle. It goes through the revs and drives fine, not down on power, if you keep giving it gas. I've changed the plugs, wires, cap, rotor. I will be checking for vacuum lines next. How likely is this to be a carb fueling issue? Also checking compression in the A.M., what should my next step be if the vacuum system checks out?
Second, what is your procedure for starting the engine? Do you press on the gas pedal or what do you do to start the engine? Post that answer too.
Vacuum diagram below: Can't remember which post I found it on so I can't take credit for it.
http://www.utoyot8.com/FullImage.asp...708%2922R..USA
My 87' ran like junk for a long time. I ended up replacing the carb, replacing all vacuum lines. Still ran like crud until I found the above vacuum diagram. I had several vacuum lines crossed. Fixed those, adjusted idle, adjusted timing, and re-adjusted the idle again. After all this, it ran perfect. The Hanes manual just did not work for me.
Hope this helps
Hope this helps
First off, if a mod could move this thread to the proper section that would be awesome.
My procedure for starting the truck is key on, pump gas petal 3 times, crank. Will not even sputter under its own power unless the truck has just been shut off.
Talking about the sight glass, when referring to the middle, do you mean the center? or the glass is 1/2 full? I will report back later. Thanks guys!
It does not look even close the half full. I can take pics later. When checking the sight glass is this after priming the carb or before? I will snag some pics and vids tomorrow, I had to leave the shop early today. Also, this truck has no emissions on it, but most of the vaccum lines are still hooked up. Is there any diagrams out there for a emmisions deleted carbed 22r?
As Crtzlow has said, it seams that the priming pump, or the main Accelerator Pump is not working or has developed a clog.
The Accelerator Pump will prime the engine when you press on the gas pedal.
Here's my picture I took of the Aisan carburetor. In the red circle is the Accelerator Pump's jet. In this picture the air horn is off, but that jet will still be visable when looking down the carb throat. When you look down the throat, operate the throttle by hand, the throttle linkage is on the oposite side of the sight glass, and look for gas squirting out of that jet.
Let us know your results.
OK, that is the correct procedure. I just wanted to make sure.
Im not an expert with carbs like slo-mo; replace your vacuuum lines, all of them, its very cheap. Make sure they are connected correctly (years of previous owners?) Check out the vacuum diagram that I posted earlier. Check and adjust timing, adjust idle. Still having problems, dig into the carb. This sequence just might surprise you!
That is if the manual linkage has not been tampered with.
Engine has ~150psi on all cylinders dry and cold. The oil in it reaks of unburned fuel. I know for a fact that there is a major vacuum leak. One of the bolts holding the carb to the manifold is missing.I will probably pull the carb off to be inspected/rebuilt, reasemble with new gaskets and re-do all of the vacuum lines while completing the 1/2 done emissions removal. Does anyone have a vacuum diagram or pics of a 22r carb with no emissions?
91toybeater
Dec 27, 2015 07:46 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
