Engine Swaps Swapping an engine in your Toy, here is where to learn how
1988 4 runner - 3.0 swap to a 3rz
Old Dec 2, 2012 | 08:28 AM
any one do this ? I see the 3.4 swap is very popular , but I have a thing for 4cyls . I'm in the gathering info stage right now , I need to get my wifes 2011 Tundra paid off , and i was thinking about buying something newer , but would rather upgrade what I have now !
Old Dec 3, 2012 | 01:35 PM
Hadmatt54's Avatar
I understand the upgrading idea, but how much fab work do you want to get into?Seeing as your 88 is a 3.0 the 3.4 is basically a drop in swap, with the exception of the wiring. If your's is a manual then the 3.4 with a 3.4 clutch bolts up to the existing transmission with no problems. If manual then your transmission is a R150F, if you go to a 3RZ-FE, you either have source a "w" series transmission and gear transfer case, or you can buy a bellhousing from Toyota ($380.00), that will allow you to bolt a 3RZ-FE to your "R" series transmission. You will also have to fab motor mounts and probably will have to move your transfer case crossmember, new drive shaft and of course there is the wiring to take care of as well.
It comes down to how complicated you want to make your swap and if your truck is an auto....your swap just got more complicated.
Old Dec 3, 2012 | 09:42 PM
kiyobrown's Avatar
Go 3.4. The swap is a mesh of 3.0 and 3.4 parts, all of which you will already have. Except you might need to find different 3.0 motor mounts. And you can use the 3.0 flywheel and clutch or the 3.4 flywheel and clutch. Plus since it has been done there are threads to follow and a knowledge base to pick from.
JF9243176
Oct 8, 2017 04:21 AM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Alaskan91
Sep 21, 2015 04:39 AM
JF9243176
Jun 24, 2015 04:53 AM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
