how do I id gear ratio
ok m 94 runner 3.0 auto has started to make bearing noise in the rear
i may have located a complete rear end for cheap so I may change it out
I need to find the ratio of the gears can this be done by vin or is there supose to be a tag on diff
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
http://www.off-road.com/trucks-4x4/t...ion-18588.html
this will help you to figure out your ratio using the A/TR code found on the ID plate on the inside of the driver's door jam.
Here is my vin
JT4VN36H9R0018788
JT4VN36H9R0018788
Ok since I think I really only need a right axle I see in some used parts they want to know if it was 2 or 4 wheel abs Is there something on axel different Or as long as it is a abs axle
It needs to be from a vehicle with the same axle code(and ABS if that's what you have). Or from another 4WD truck or 4Runner with the same gear ratio(and ABS if that's what you have). 2 or 4 wheel ABS has nothing to do with it, because it's a rear axle(since if you have 2 or 4 wheel ABS, the rear axle has ABS either way, that's why it's not even called 2 wheel ABS, it's called rear wheel ABS, or 4 wheel ABS if the front has ABS too).
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
