Sponsored by: CARiD
Old Feb 9, 2016, 09:41 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
rear window relay "fix" 2nd gen 4runner
Old Sep 23, 2012 | 01:03 PM
jmswltn's Avatar
here is how i "fixed" my rear window relay.
this is only how to i got my rear door/window to operate after my relay box was damaged. no defrost or wiper but the window rolls up and down.. without a key even.
pretty sure any 12v relay would work but these were the radio shack ones suggested to work with the original board in another post. my board had bad traces on it so i used these in this write up
i needed to use my tail gate this was the fix
Old Jan 15, 2018 | 09:31 PM
Ducas21's Avatar
Sorry for adding to a old post. I have a idea that I need a few opinions on. I have one that’s not working with the key. I need access to it from the outside. I was thinking about cutting the power to the motor and hooking up a hidden outside switch with a different power behind the spare tire or something like that. That way the motor has a separate power without the relays. What do you guys think?
Old Jan 15, 2018 | 10:27 PM
Co_94_PU's Avatar
I think you should start your own thread, probably after you do some research on how to trouble shoot the rear window safety system.. There is lots of coverage on this.
Start a new thread and we'll walk you through your problems.. You need to be clear on what year, what you've done and all that sort of stuff.
Old Jan 15, 2018 | 10:30 PM
RAD4Runner's Avatar
... I was thinking about cutting the power to the motor and hooking up a hidden outside switch...
Don't.
Find schematic, get a multi-meter, research, test all interlocks. Disconnect wiper assembly connector to absolutely eliminate wiper retract switch as culprit.
Old Jan 15, 2018 | 11:08 PM
wyoming9's Avatar
Red face
Concur fix it the correct way !!!
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
marcusSRG
Jun 27, 2015 07:13 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
