3rd gen aussie locker
Originally posted by BruceTS
Are you Kidding? Or is this supposed to be a trick question?
ARB
ARB
the ARB locker is $650 and a compressor is another $200 plus $300 for install.
not a trick question, not everyone has that kind of dough.
Soft locker: Disengages based on rotation and pressure while turning to avoid severe tire wear and loss of control on slick roads, its either on or off.
LSD: Limited slip, which means it will spin both tires under certain conditions, but with too much pressure from one side or the other, it will slip to prevent tire damage. Better for street use.
Selectable: Either on or off. Best for street use because you can turn it off on command.
The 8" V-6 4 pinion application is still not out. That will work for all V-6 Toy 8" thirds.
Lockers lock both sides together when throttle is applied.
LSD's lock both sides together when one side slips and will release again should the side to side difference become too much.
ARB's and E-lockers lock both side together when the switch is depressed and unlock when it is pressed again.
I would not spend my money on anything but a selectable locker.
ADRIAN enters the building! So what might he have to say now?
So this means??
It means they don't make one for you, yet.
So, in an earlier thread I suggested you try an aussie locker (I didn't know they weren't out for the V6 thirds) and you automatically rejected it. But now you say you don't even know what it is?
