My 1992 yota finally on the road
Here she is all cleaned and fixed up. New break lines front to back. New fuel line. Gas tank raised flush with the chassis. ball joint spacers 3 inch body lift. 31inch tires with offset rims. Its got some sort of locker that I installed with new rear wheel bearings and seals. I installed new front rotors and with manual aisin locking hubs with new 0 ring seals. New horn relay. I sprayed these gray floor mats with gravel guard that came with the truck. I just installed some front shocks from an old 4 runner that look like they had been replaced and are very strong.
What type of locker starts hopping around corners when you put power to the wheels but if I coast around the corners or use the gas pedal lightly going around corners or U turns the outside wheel spins freely but If I put any power to the wheels while turning it will either screetch hop a little or If I gave it enought power both tires would break loose and I would drift. Any Idea on what kind of setup would do that? Some guy said he paid like 800 for the carrier with the locker and I just had the back lash set and installed it into the rebuild differential.
http://i1161.photobucket.com/albums/...and/IMG066.jpg
http://i1161.photobucket.com/albums/...and/IMG068.jpg
The dash is apart because Im waiting on some 4 inch pincer speakers from ebay.
Sep 4, 2015 09:27 AM
nframe
3.4 Swaps
Aug 16, 2015 09:03 AM
jon.r
Jul 11, 2015 03:34 PM
