Stripped oil pan plug! 87' 4x4 pickup
So i did my routine oil change & apparently strong armed my plug... Its now stripped and leaking all over my driveway. It would be SOOOO AWESOME if anyone has any ideas on how to get the POS to back out of the hole. It spins freely and catches rarely but never enough to get the threads started again. Do i have to drop the pan? Any crazy ideas would be greatly appreciated, its my only rig and i need it for school lol
Vise grips, really tight, and pull out as you thread it out. Once you get it out a wee bit, you can get a screwdriver/pry bar under the shoulder and pry slightly as you thread it out.
But it's a good chance that the pan is stripped as well, because it's usually softer threads than the bolts, so be prepared to do a pan as well....
Usually it begins when someone along the life of the truck installs a drain plug with a slightly different thread pitch. Or just a little more tightening every time the oil is changed. It eventually makes the threads so thin that just a few in/lbs of tightening will be the end....
In all honesty, you're gunna have to bite the bullet on the cost of the oil that you put in and drop the pan...
Get a large oil collector, some gloves and get ready to get dirty. Drop the pan, give it a good cleaning and get that bolt out of there. If you're lucky, you can chase the threads. If not, you're going to need to a slightly larger size and tap to that size. Before you put the pan back on, bring it on down to your local hardware store and find the matching size hardware. Get a new washer/rubber while you're there.
Do it right with FIPG from the dealer. It cures FAST so I recommend you do a few practice runs on installing the pan without the gasket material on, so when the time comes, you can do it fast, without smearing FIPG all over the place (use gloves, that stuff is nasty (why it's so good at what it does!).
You have IFS so you may need to drop the front diff to make room for the pan.... Oh, and note that you have an oil pickup tube in there, which will get in the way when taking off the pan AND installing it.
When you install the new one, make sure surfaces on the block and the pan are CLEAN (brake parts cleaner and razor blades), and then snug up the 14 (?) bolts, but not 100% tight....do it in a "star" pattern so you tighten it evenly and it's flush to the block. Let it sit overnight. Then, take your torque wrench to it and tighten to 9 lb/ft each, again in the star pattern.
THEN, fill up with oil.
GL!
Just a heads up.............. You can go to Napa, if you can't get time right now to pull the pan(Like I couldn't at the time! lol)... And pick up a Self Tapping Oil Pan Drain Plug for your year vehicle/threading. Mine has been in for 8K miles, hasn't leaked a drop since! And yes, I've changed the oil 3 times since installing it. I think it was worth the 11$ or whatever it was to TRY, rather than dropping my Pan which was FINALLY not leaking after 3 times in there in 2 years(bad machinist, don't ask, lol).... just FOR A BOLT? GRRR! haha.
Just a thought... If you can't get the dayum bolt out, that's possibly beyond 'SELF TAPPING DRAIN BOLT'... Not sure.
BTW, the type I have is a dual stage... It has the bolt you thread in.... and then a smaller one that you drain from. I used a lil bit of Toyota FIPG on the bottom one, the one with the washer they supplied, and torqued it up in there til really snug and pressing out the FIPG... And as I said... been leak free since
BTW2; This was on a pan that I SWAPPED IN ON THE LAST REBUILD I DID! I tested it as best as I could.... But after a few days, it began leaking hot oil.... TICKED! lol. My original pan got bent and I didn't wanna mess with it... So I got one from the Parts yard for 20$. SHOULDA GOTTA NEW ONE, IMHO! lol.
here's a pic of the self tapping bolt..........
Nothing against FIPG, but Ultra Black/grey is a bit cheaper and works just as well. It is oil and vibration resistant. I have used it on countless oil pans, valve cover half-moons, and front cover gaskets. Never had a leak. Put it on, let it cure, done. I have it as my 3RZ oil pan gasket and in 25K miles since the swap, no problems.
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
