front rubbing in 4wd (not tires)
Old May 11, 2012 | 01:01 PM
lastname_firstname's Avatar
So I was wheelin last weekend in eastern washington and found some pretty sweet terrain, but since I bought my truck I've been hearing this heavy RUUUUUUB RUUUUUUUB sound coming from what seems to be near my left front wheel. I have a strong suspicion that its in my steering, but has anybody else experienced this? I'm sure its not rubbing on my fenders, and it only happens in 4wd, hi and lo. It also seems to put a fair ammount of friction onto the wheels...like enough to stop the car from rolling even when its on small hills.
Any tips will help, thanks.
Old May 12, 2012 | 08:23 AM
Bumper
Old May 12, 2012 | 08:52 AM
vanduzerwilliam's Avatar
My truck doesn't roll in 4lo harndly at all there's friction because its in 4.. just IMO idk im not a toyota expert.
But possibly your axle on the front left?
Old May 12, 2012 | 09:29 AM
Luvmeye22re's Avatar
My truck makes that noise all the time and I'm quite sure it's the front driver side axle. Mine is ADD so the axles spin even in 2wd. The boot is torn and it was when I bought it a few weeks ago. Check the boots on your front axles, if one is torn it's probably an axle.
Old May 12, 2012 | 12:18 PM
rbmoomba's Avatar
Is the runner stock? possible friction of driveshaft and crossmember when it is torquing up. I had this issue with my first built crossmember and dual t-cases. Just an idea
Old May 30, 2012 | 02:05 PM
The pickup is stock, only mod is the 3.4l engine. After some more trail runs it seems like it doesn't have enought grease in the axles or something. Seems to work fine when I just barely use it, but heavy usage in 4wd causes the rub, which, when it happens, is getting worse.
Old May 30, 2012 | 02:06 PM
So what's the remedy? Is there anything I can fix w/ some grease and zip ties, or duct tape?
Old May 30, 2012 | 02:23 PM
I used liquid lubricant sprayed every joint I could think that would make noise, and magically all the noises went away, try this might work for you, and its like 8$ a can for what I bought.. 8$ for no more noise is money well spent to me
Old May 30, 2012 | 02:40 PM
Dually noted. Did you use a certain kind or was it just any liquid lube, like wd 40?
Old May 30, 2012 | 02:46 PM
I would use a non dirt attracting lubricant, ask the parts store when you go, any lubricant such as 226, not wd40 because it pulls in dust/dirt.
I think it was made by luiqud wrench not completely sure don't have the can on hand to check
Old May 31, 2012 | 06:55 AM
Team420's Avatar
If ur cv shaft is toast, which, if the boot is torn, dirt has gotten in there, I would replace that a.s.a.p.... ever seen a cv shaft come apart at 60 mph? I have, and it aint pretty.... Fix the obvious stuff 1st, and move on from there.... Or... invest in some manual hubs, and only lock them when absolutely needed... and even then, dont be surprised when it comes apart and leaves u stuck in a mud hole....
Old Jun 1, 2012 | 09:25 AM
Ok, so it happened real bad today driving to work in 2wd on the freeway goin 65...pulled over, hopped out, gave it my mean look and it was fine the rest of the drive (but I didn't dare go over 65).
Boot doesn't look torn, but it seems as if something is twisting it from the inside. Took a pic will post up what I'm talkin about later
Old Jun 8, 2012 | 09:56 AM
[YOUTUBE]http://www.youtube.com/watch?v=9Hlee...ature=youtu.be[/YOUTUBE]
I attempted to roll down the window shortly to get a better recording, didnt work. im thinkin its my DS CV up front, and I drove it like this ~10 miles to work and will be driving it home this afternoon to tear into and fix tonight and tommorow, any help is appreciated
Old Jun 8, 2012 | 11:43 AM
calcuta's Avatar
spindle bushing need to be lubed
Old Jun 8, 2012 | 11:47 AM
Bushing or bearing?
Old Jun 8, 2012 | 11:53 AM
vital22re's Avatar
totally a bro
Indeed. You need to pull the axle out and tear apart that spindle More than likely the brass bushings are toast.
Old Jun 8, 2012 | 12:32 PM
Ok so next question, how did this happen? Bad seals? Too many mudpuddles? I did wheel bearing on that side about 3 months ago but was positive I put enough grease back in it...
Old Jun 8, 2012 | 06:03 PM
Yea...so I followed the instructions to take cv out. Out of the fsm...no dice. Got fed up and grinded it in half, any advice on getting the new one in??
Old Jun 8, 2012 | 06:18 PM
toyota4x4907's Avatar
Oh, young grasshopper
Disconnection of the lower ball joint (4 bolts) makes this job 10000 times easier.
Old Jun 10, 2012 | 05:32 PM
calcuta's Avatar
bushing . search spindle lubricator will show you how to make a tool so you wont have too take it apart
djpg2000
Nov 11, 2020 04:56 AM
Sep 4, 2015 09:27 AM
adammtb
Jul 27, 2015 11:57 AM
TokyoD23
Jul 12, 2015 06:01 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
