94 fuel pump change out
Old Apr 22, 2012 | 10:46 AM
94Beater's Avatar
What is the easiest way?
Old Apr 22, 2012 | 11:11 AM
scope103's Avatar
I've never done it, but I'd start with reading the manual.
http://www.ncttora.com/fsm/1990-1995...e/fuelpump.pdf It doesn't look that hard.
Old Apr 22, 2012 | 12:39 PM
TNRabbit's Avatar
Easiest way is to pay someone else to do it.
Which engine/vehicle?
Old Apr 22, 2012 | 05:18 PM
Rob510's Avatar
Is it a truck or 4runner? If it is a truck, removing the bed isn't that bad. Start by spraying your bed mount nuts with PB blaster or something better than WD40 a couple of days ahead of time. Then remove the tailights and loosen the harness from the bed, disconnect the fuel filler neck, and remove all the nuts that hold the bed on from underneath. I used two ratchet straps to make a x across the bed hooks then an engine crain to lift the bed up and moved it back and rested it on the tires. That will give you enough access to get the pump out.
Old Apr 22, 2012 | 05:20 PM
Rob510's Avatar
Oops double post
Old Apr 22, 2012 | 06:29 PM
TNRabbit's Avatar
Pics here for a pickup:
https://www.yotatech.com/forums/f116...repair-239734/
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
