Did Jiffy Lube use the wrong fluid for my T-Case?
Old Mar 4, 2012 | 07:23 AM
Vang530's Avatar
Exclamation Did Jiffy Lube use the wrong fluid for my T-Case?
1985 Toyota Pickup Xtended Cab SR5 4x4
22RE
AUTOMATIC TRANSMISSION
Just bought this truck a couple weeks ago. Went to Jiffy Lube the other day to change out my transfer case fluid and the guys there said why was there ATF Fluid coming out of my T-case?.... They said it calls for GL-5, not ATF which is apparently only used in the v6, so they went ahead and put in GL-5 in my t-case.
So...what fluid really goes in the t-case for the '85 pickup auto trans?
Should I go back cause they screwed it up or am I fine with GL-5 in my t-case for the auto trans?
I've searched and google'd but still get conflicting answers...
Thanks
Old Mar 4, 2012 | 07:32 AM
rworegon's Avatar
Look it up in the FSM - Factory Service Manual linky below.
Ya' may want to edit your post as I see boxes where the language filter hit a bad word....just saying.
Old Mar 4, 2012 | 07:44 AM
Vang530's Avatar
I looked at this one: http://www.ncttora.com/fsm/1985/1985FSM.pdf
and it also says to use GL-5 but does not specify if its for the manual or auto trans
Old Mar 4, 2012 | 10:32 AM
Vang530's Avatar
Just went ahead and checked my Chilton manual as well and it calls for ATF fluid for the transfer case for automatics... god this is so confusing
FSM says GL-5 but doesn't specify what transmission type
Chilton says ATF for auto trans
Jiffy Lube says GL-5 for auto trans?..
Old Mar 4, 2012 | 10:39 AM
bobby_duce's Avatar
your problem is that you went to jiffy lube. im not knocking on anyone thats on this forum who works there cause there are some good people that work at jiffy lube but id say most of the people who work there dont have a clue. ive heard nightmares of things happening after going to this place. wrong fluids, not screwing the oil filter back on all the way... then stuff going wrong. once you research it and if you find a mistake bring it back and tell them to fix it. my .02 cents
Old Mar 4, 2012 | 10:46 AM
MudHippy's Avatar
The FSM states API GL-4 or GL-5, SAE 75W-90 for all 1985 PU & 4Runner transfer cases. Nevermind what Chilton says, not the most reliable source for specifications.
Any more questions?
Old Mar 4, 2012 | 10:50 AM
daved5150's Avatar
I have the same site saved on my desktop here at work but it's the section for the 90 to 95 4Runners. According to that, the 3vz-e gets dextronII and anything except the 3vz-e (22re) gets 75W90 gl-4,5. I would use gl-4 for a t/c with a manual tranny. I was looking at marlincrawler.com and it looks like:
"all 1979-1995 gear drive transfer cases.
This is the most complete kit on the market! Includes our Heavy Duty rear EcoSeal, all seals including the transmission output, felts, speedometer sender and oil pump o-rings, top and forward shifting base gaskets, as well as L-, G-, and W-series transmission tailhousing gaskets. Please select 21- or 23-spline for the transmission output seal type."
I don't know if the chain drive t/c's take different oil. I'll try and look into more for you. You can also see which one and look for threads about the subject here. Both my 4Runner's are manuals and they take the GL-4 oil. I believe my 88's t/c was chain and took the same oil as the gear case. And I believe my cousin's 95 auto took ATF in the transfer case. Check out: http://www.marlincrawler.com/tech/tr...fer-case-bible
Also from Marlincrawler's site: Hope this all helps you out.....
How to ID Gear Drive Case
If you have 7 bolts in the rear cover then you have the gear driven unit.
If you have 5 bolts holding the rear cover then you have the chain drive unit.
Bolt #7 is behind the drive shaft and can't be seen in this picture.
Attached Thumbnails Did Jiffy Lube use the wrong fluid for my T-Case?-getratio_tcount.jpg
Old Mar 4, 2012 | 01:16 PM
Vang530's Avatar
Any more questions?
Thank you! I will go ahead and keep the GL-5 in there. Would having any ATF in my t-case from the PO ruin anything?
Thank you for all this info. I am going to bookmark this.
Yeah I know people usually crap on Jiffy Lube but I've been going to ours for over 4 years now with no problem (small town) until this happened.
Old Mar 4, 2012 | 01:53 PM
rokblok's Avatar
A lot of chain drive cases use ATF. It's just a light viscosity oil with red dye and a lot of detergents. I think most all the NP cases use ATF.
Old Mar 5, 2012 | 02:47 PM
ephwang's Avatar
Might want to read this ...
A340 Transmission issues and FAQs
Marsheen
Feb 17, 2016 12:29 PM
priest16
15
Aug 6, 2015 07:43 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
mr_manny
Jul 31, 2015 10:39 AM
89hilux1
Jul 19, 2015 01:32 AM
