transmission mount fell out
Old Feb 9, 2012 | 06:13 PM
mcgunn74's Avatar
So today I get to work and notice this rectangular chunk of rubber beside my truck. A friend of mine identified it as a tranny mount. I looked and sure enough, there it was, gone. My question is, can I reuse the old mount, or is this a sign it needs to be replaced? The old mount looks to be in good condition. Also, I drove about 100 miles of Maine winter roads today, anything I should look for as far as more damage?
Old Feb 9, 2012 | 06:27 PM
peow130's Avatar
rofl..
Well, if its ON THE GROUND NEXT TO IT... you probably should just buy a new one..
Isn't there like 8 bolts holding that thing on anyways? Unless of course yours just spit the rubber, which means you need a new one regardless.
You'd think you'd notice if your transmission was just freely torqueing everywhere
Old Feb 9, 2012 | 06:32 PM
mcgunn74's Avatar
Just the drivers side rubber.
Old Feb 9, 2012 | 06:34 PM
peow130's Avatar
Lol dude, just buy a new mount.. Trust me, if the old one spit the rubber out, the other side isn't too far out. Buy a new one now before you start tearing motor mount rubber, if you haven't already.
Old Feb 9, 2012 | 06:38 PM
mcgunn74's Avatar
the actual metal mount looks like a V welded to the frame, and a flat bracket bolted to the transmission. Is there more than the rubber bumper to replace?
Old Feb 9, 2012 | 06:43 PM
peow130's Avatar
There should be a cradle that bolts onto your transmission, then it bolts to the tranny crossmember, unless somebody bubba'd up somethin..
Old Feb 9, 2012 | 06:51 PM
mcgunn74's Avatar
The metal mounts all looks sound, not rotted at all. If its just a bolt on, new ones on the way. thanks for the help and glad you got a laugh.
Old Feb 10, 2012 | 07:35 AM
mcgunn74's Avatar
OK so I called the parts stores around including the dealership and it seems the closest transmission mount is in Tokyo. I ask again, if the mount and the rubber still look good can I put the rubber stop back (safely for a bandaid)in the mount for a couple of days until the new one arrives?
Old Feb 10, 2012 | 08:11 AM
yotaman85's Avatar
if you can get it to go back on, then yes.
Old Feb 10, 2012 | 09:40 AM
rustyf99's Avatar
Is it an Auto 4x4? If I recall correctly, they have a huge rubber balance block on the back that is maybe a vibration damper that is not really a mount at all, I am not sure exactly what it does. I may have an extra in the shed if you want it, but I'm near Chicago ... shipping would be $$ due to the weight? PM me if you're interested though.
Old Feb 10, 2012 | 09:42 AM
peow130's Avatar
Check rockauto.com.
Yeah, stick the old one in and use a ratchet strap or something to keep your transmission from flopping around everywhere.
Old Feb 10, 2012 | 11:04 AM
khany2002's Avatar
I bought one from Rockauto maybe a month or two back. If I may, buy the Beck Arnley one -- it had an OEM part number stamped on the side of it.
If you're buying motor mounts at the same time, buy the craptastic brand -- both of those are made by the same manufacturer, Beck Arnley just reboxes them and sells them for double the price. Those are not made by OEM though (I can't comment on performance as I have not installed the motor mounts yet).
One wierd problem I've got with the new mount (perhaps you may run into it) is that even though the old mount is IDENTICAL to the new one, I was able to get two of the bolt in on one side of the tranny, but the other two just would not go in. Of course, I've got the two on the cross member in, as well as two on the right side, and I don't really drive the truck in the winter, so I'm just letting it settle and I'll check if I can reinstall the bolts in the spring, but still, it's annoying -- I tried even using a punch to align the holes, but even with considerable force, the bolts don't really align well -- I suspect it's because of fresh rubber.
Anyways, if anyone has dealt with this, let me know, and for OP, I paid $50 or so for the rockauto beck arnley unit -- yours definitely needs replacement.
Old Feb 10, 2012 | 10:28 PM
Philbert's Avatar
Trail gear sells them too.
K just got their "bomb proof" mount for my truck. They sell the oem mount too but it is double tge price
Old Feb 11, 2012 | 02:52 AM
wyoming9's Avatar
Red face
Be nice to know just what it is that this fell out of??
I have a bunch of new ones for the 87/88 vintage trucks/4 runners.
What a load of bull no one has one.
Unless yours is a real odd ball or the first Toyota 4x4 in the USA
Old Feb 11, 2012 | 03:17 AM
dropzone's Avatar
Fossilized
just what year truck/auto/stick/engine are we referring to? sounds like an auto & kind of BS no one has one..replace them as it will fail again
t-g stock mount:
bombproof style:
my transmission actually has no mounts--they are on the engine and transfercase (x2)..
Old Feb 11, 2012 | 06:23 AM
mcgunn74's Avatar
Thanks again for the help everyone. The truck is a 5 speed 4x4. The new mount is already purchased just waiting for it to arrive. Got new cab and motor mounts too, but Ill wait for spring when I can address the frame to do those. also checking the salvage yard today for a temporary one.
crammit442
7
Nov 29, 2017 12:30 PM
mskalmus
May 28, 2017 07:51 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Tigbucket
Jul 30, 2015 07:29 PM
HookahRoo
Jul 20, 2015 07:06 PM
