Can i use auto harness and auto ecu with 5speed trans
Old Feb 7, 2012 | 01:07 PM
kauaiboi15's Avatar
Is it possible to use both auto ecu and harness from a 98 tacoma with the 5 speed trans from my 91 pickup? Need help asap!
Old Feb 7, 2012 | 04:13 PM
QuickSilver74's Avatar
i'd like to know also. my donor is a 99 runner with auto and going into my 90 runner with a 5speed
Old Feb 7, 2012 | 04:16 PM
kauaiboi15's Avatar
Ive heard you can just make the ecu think the truck is in neutral then your good to go but im not completely sure how and i dont feel like spending anymore money on the swap
Old Feb 7, 2012 | 07:09 PM
Greg_Canada's Avatar
With the 98 auto harness you can use a 98 4runner or taco manual ecu and it will work no prob. Not sure if the auto ecu will work.
Fyi this only works on 98's.
Old Feb 7, 2012 | 07:37 PM
waskillywabbit's Avatar
Have you guys read any of the links in the FAQ? Or on ORS links?
:wabbit2:
Old Feb 7, 2012 | 07:56 PM
dntsdad's Avatar
Depends on your definition of "works". It'll run and function but you will get a check engine light that won't go away.
In some states that is an automatic failure for smog.
Old Feb 19, 2012 | 06:39 AM
:wabbit2:
the ORS links were dead last week when i tried..............
Old Apr 7, 2014 | 08:33 PM
RcBro's Avatar
How are you guys "fooling" the auto ecu? I assume you are connecting the NSW from the ECU to the 7.5A Start circuit?
Or is there more.. I just wired a swap but wasn't able to see it fire. It is not getting spark and i'm wondering if I still need to fool this ECU somehow. I haven't had a chance to trouble shoot anything else but trying to do some homework till I can get back to the shop.
Old Apr 15, 2014 | 08:14 PM
david braun's Avatar
The wiring diagram is identical between the 98 auto and 98 manual ECU's I have looked, if your getting a check engine light I would like to know what code for.
As for making the auto ecu work with the manual tranny you will have one code po1700 which will not go away because of the lack of a rear trans speed sensor resulting in a check engine light but will not effect the engine systems.
The others can be fooled with 3 resistors for the shift solenoids and the trans temp sensor just plug it back into the harness.
Jump neutral and park wires or run them to a clutch cancel switch I never did.
Old Mar 23, 2015 | 02:30 AM
pineymudder's Avatar
Im running a 96 auto computer and harness. I didnt fool anything but i do have check engine light for 2 or 3 shift solenoids and a trans fluid temp sensor. Truck runs great other than that. I just unhooked engine light wire to dash. (Purple wire) nj only looks for engine light after 96 models. Obd1 stuff doesnt matter. I have good inspection sticker and nobody even noticed. I almost passed with no cat, but inspector was looking all over for it. I had to put aftermarket cat on to pass.
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
DeathCougar
Apr 1, 2018 11:29 PM
deepmarsh
Aug 6, 2015 03:44 AM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
KBar
Jul 13, 2015 06:01 PM
