Pre 84 Trucks 1st gen pickups
Parked for 3 weeks now won't start.
Old Feb 5, 2012 | 12:44 PM
Schnayke's Avatar
Ok so I parked my truck because it was nearly out of gas, and i was out of money for 3 weeks. I got in it to go fill it up and it won't start now, just cranks over and over.
I have a question, how do I check if it is getting fuel?
I think it is not getting fuel because I couldn't smell any even after holding the gas down while trying to start it for some time. At this point the battery is dead, and I need to recharge it.
Clogged fuel filter? bad pump? Cracked line? Are those the things I should be looking for?
I have a webber carb, and its a 1983 toyota pickup with 22r motor, 4 speed, 2wd, short bed.
It was running ok before I parked it a few weeks ago.
To be clear its not even trying to idle, just turning over and over with no action.
Old Feb 5, 2012 | 12:46 PM
FourwheelinVT's Avatar
Did you put any gas in it?
Old Feb 5, 2012 | 12:54 PM
Schnayke's Avatar
yeah I added about 3 gallons.
Old Feb 5, 2012 | 01:03 PM
Maybe it just needs to be "primed"? Did you try pouring a small amount of gas in the carb? Was your truck running fine when you parked it?
Old Feb 5, 2012 | 01:06 PM
igotit's Avatar
My 82 does this aswell, the fuel has drained back to tank over time.
As suggested,pour a little bit of gas into the carb, then fire her up.
Should run rough for a few seconds untill the pump pics back prime.
My 82 stays parked for upto 4 weeks sometimes.
Old Feb 5, 2012 | 01:25 PM
Schnayke's Avatar
I have not tryed putting fuel in the carb I will try that when I get home. Cross's fingers that its the problem. It did run fine when I parked it.
Old Feb 5, 2012 | 01:47 PM
justin_4runner's Avatar
after sitting for a 2 weeks i usually had to pour gas down the carb to keep it running for a min then it would get gas again and run fine,
Old Feb 5, 2012 | 04:16 PM
Schnayke's Avatar
Yup you guys where right, just had to put some gas in the carb. Thanks, also found a fuel leak I wouldn't have if I didn't have this problem. Its up and going and the battery is getting topped off right now. Thanks again.
sandyota
Feb 4, 2021 11:16 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
KBar
Aug 3, 2015 05:14 PM
Poncho0206
Jul 10, 2015 06:21 PM
