Loud squealing after 3vze rebuild
Old Jan 29, 2012 | 04:27 PM
70elcoss's Avatar
Ok so I rebuilt my motor completely, new bearings pistons, rebuilt heads, and new timing belt kit and today I finished the motor install and got it to run but the idle is just a little rough and it makes a loud squealing almost screeching noise while it's running and gets louder as rpms increase.... It sounds likets coming from either the throttlebody area or the distributor area so I took out distributor and checked to see if it was properly lubricated. It was so I messed around by turning the distributor while it was running and the noise got very quiet when I turned it all the way to the left but came back when I accelerated.
Anyone have any idea to what this is? I'm exhausted and need to get it running right already. Thanks!
Oh it's almost like a super loud belt squealing noise. I initially thought it might be the alternator belt because I'm reusing it but it's just too loud to be a belt squeal I think....
Old Jan 29, 2012 | 05:25 PM
justin_4runner's Avatar
double check the alt belt to see how loose it is. also have u checked to see if the bearings in the dist. are good? i would pull it out and see how hard it is to spin the dist. shaft.
Old Jan 29, 2012 | 05:35 PM
rattlewagon's Avatar
Its really hard to guess a sound over the internets...any way you can get a video or sound clip?
Old Jan 29, 2012 | 05:50 PM
70elcoss's Avatar
Eating dinner and taking a break right now lol I'm physically and mentally exhausted! Hahaha I really think it's coming from the alternator or the belt because it is an old belt. I'm gunna disconnect it a little later and run it like that to see if it still makes the noise. Distributor seemed ok even before the rebuild
Old Jan 29, 2012 | 09:11 PM
70elcoss's Avatar
ok so took all the alt, ps, and ac belts off, prayed turned the key and it still screeched! i was frustrated so i just started feeling around the intake area and found it! it was the throttle body! the bottom two bolts were loose so i tightened them and it went away almost! still slightly hear it so im gunna take it off and clean it up real good and throw a new gasket on it... when i put it back on i used a new gasket but some pieces of the old gasket were impossible to get off so i so it off as good as i could... well it obviously wasn't good enough lol
relieved it wasnt an internal noise hahaha thanks guys!
Old Jan 29, 2012 | 09:16 PM
good deal, always a good feeling when its not a big price item going bad....
Old Jan 29, 2012 | 09:39 PM
70elcoss's Avatar
HUGE relief! haha when i drove it for the first time it stumbled a bit around 3k rpms but im just gunna mess with the timing tomorrow im pretty sure thats what it is.
Old Feb 26, 2015 | 06:39 PM
1989toyota3vze's Avatar
Exclamation 3.ooohno
Hi their have a 1989 3.0 did a rebuild on the motor about 8k ago check engine just came on yesterday then all of a sudden today my truck squeaks when accelerating first second and 3rd if I am bogging it or floored but not when I let off or am consistently on the gas any help ?? And I just replaced my acbelt and pulley bearing and I did notice my fan has some play any advice would be apreciated thank you
Old Feb 27, 2015 | 09:45 AM
70elcoss's Avatar
I haven't been on here in a while! But after breaking in the motor a new screech developed and It was screeching consistently throughout all rpms. It turned out to be the alternator bearings, replaced the alternator and now she's quiet as can be! I would replace the belts one by one to try to isolate the problem. One thing I did too was spray wd40 with the motor running on the pulleys and belts to try to find out where... I would do that with the old belts not the new ones.... When I sprayed wd40 on my alternator pulley it stop making noise, replaced the belt and still made the noise so I replaced the alternator and fixed it
Old Feb 27, 2015 | 09:47 AM
70elcoss's Avatar
I can't help you with the fan though because I have an electric fan on mine so my setup is different
Old Mar 18, 2015 | 04:00 PM
70elcoss
Hi sorry for the late reply turns out it was my ujoints in the rear axle one of the bearings was seized bought both front and rear u joints for the rear drive line back to flawless again now just saving for that sas swap
jashoeuh
Nov 18, 2024 08:08 AM
JNapolitano
Nov 14, 2019 07:46 PM
Team420
Dec 30, 2015 01:31 PM
lmobeats18
Aug 28, 2015 04:57 PM
PlayAwhile
Jul 20, 2015 11:36 AM
