Sponsored by: CARiD
87 4 Runner Egine Swap Info
Old Dec 20, 2011 | 10:01 AM
DanoB's Avatar
Hello
I have an 87 4 Runner with a blown/cracked 21R-U motor. I know that the questions has been asked many times but what is my easiest motor swap option. I know the 22RE is probably the easiest for plug and go but not sure if their was any adjustment needed to put in the 21 R-U. Thanks.
Old Dec 20, 2011 | 10:07 AM
Leviticus6432's Avatar
Go chevy 4.3 carb. 3 wires man, 3 wires... I however went 4.3 tbi hundreds of wires lol
Old Dec 20, 2011 | 10:09 AM
muddy chevota's Avatar
skip right past the 4.3 and go 5.7 350 little more work twice the pleasure
Old Dec 20, 2011 | 10:11 AM
but they are heavvvy and the drivetrain will have trouble holdin up
Old Dec 20, 2011 | 10:12 AM
DanoB's Avatar
thanks guys, but I'm wanting to stay toyota engine.
Old Dec 20, 2011 | 10:15 AM
Bassmastry101's Avatar
Go 22r..I had to look up what a 21 R-U was and it looks like its just the imported replacement to the 20r. So it should fit with no problems.
Old Dec 20, 2011 | 10:17 AM
i have NEVER had a problem with any of that im running 350 turbo 400trans and 205 T case only clown one rear axle in 5 years detroit locker rear , i added 2 leafs up front to compensate
Old Dec 20, 2011 | 10:19 AM
the 22re is a perfect replacement if staying toyota, double check the timing chain while the motor is out , not a bad idea to replace it if motor is used , much easier while out of the truck and costs about $130 total
Old Dec 20, 2011 | 10:40 AM
DanoB's Avatar
What about replacing with a 6 cylinder? I see that posted alot but didnt know how much work and mod it would be. I found an old toyota van that the motor was still good but not sure about the mounts.
Old Dec 20, 2011 | 10:45 AM
i have heard a lot of grief about the 6 cylinder motors, i would just stick to a 4 if i were you, i know the 6 mates to the tranny fine , not sure about motor mounts i would assume the same to make it easier in the factory to assembly, but im guessing at that,
Old Dec 20, 2011 | 11:07 AM
DanoB's Avatar
I found a beater truck with a 22r carbed motor. The 21 ru is EFI. can this be swapped if i pull everything?
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
luke0927
Jul 2, 2015 10:49 AM
ACZR
Jun 23, 2015 07:55 PM
TheManOutside
Jun 18, 2015 03:32 PM
