Quadracing04's 85 X-cab pickup build thread --Project River Runner
Old Nov 30, 2011 | 09:11 PM
quadracing04's Avatar
Well here is where it all starts, i was looking for something to build up and take out around all the old school trails along the river that no body has been on in years and just enjoy the day, find new fishing and camping spots and just get away from the city. So the search began and i found this, it an 85 with a bran new rebuilt motor. The guy said he could not keep it running unless it was hooked to another vehical (jump start). So 500 bucks, a test light, a charged battery and 4 hours later i have a running truck. All it was was a bad ground on the alternator, go that fixed and it started up first turn of the key and i took it out for a cruz, and it hasnt died since.
so here is my build thead, got suspension on the way, a new set of 35" BFG KM1's and a wish list a mile long. tomorrow i plan on going through everything and see what other surprises might be hiding and as the parts come in my new TOY will be getting dressed to impressed.
Hope y'all enjoy.
Attached Thumbnails Quadracing04's 85 X-cab  pickup build thread  --Project River Runner-2011-11-30_18-21-14_881.jpg
Old Nov 30, 2011 | 10:00 PM
87 Deathtrap's Avatar
Good luck with the build and welcome to yotatech!
Old Dec 1, 2011 | 02:57 AM
Terrys87's Avatar
Great looking truck. One of my favorite bodystyles. Welcome to Yotatech and looking forward to seeing more.
Old Dec 1, 2011 | 02:58 AM
Swimmerboy2112's Avatar
Welcome to Yotatech, you have quite a sought-after truck!
Old Dec 1, 2011 | 06:59 PM
Thank everyone,
Well i had to work some overtime so i didnt get off in time to do much, only thing i got accompliched was installing a direct power relay system to the head light to get rid of that crappy low power yellow look. But tomorrow is another day and my new toy will be getting some much needed TLC, all new fluids, spark plugs, airfilter......all the goodies of a good tune up.
Old Dec 1, 2011 | 10:25 PM
RMP8080's Avatar
Cool truck, you got the x-cab great, mine is reg, anyway welcome and check out the other builds. I got a lot of ideas from a lot of great trucks on this site
Old Dec 2, 2011 | 08:32 AM
The guys around here have built some amazing rigs, I probably spent more time reading up on all of yalls rigs more then working on mine. But you guys have given me a lot of build ideas that are gonna make this project into exactly what I want.
Mad props to all you rig builders, you have some amazing creations.
Old Dec 3, 2011 | 03:55 PM
Been stuck on the same problem for the last 2 days, the altenator will only charge 12.5 volts. i put a brand new one in and it is still putting out the same. any ideas on what it could be?
Old Dec 3, 2011 | 06:16 PM
RMP8080's Avatar
check for a short in the wiring. also run the truck with the wire that go's from the altenator to the battery off and check the voltage out of the altenator only.
Old Dec 3, 2011 | 09:28 PM
alright, i tried that it is still only showing 12.5, is there an external regulator or something? becuase i thought these were internaly regulated.
Old Dec 3, 2011 | 09:45 PM
RMP8080's Avatar
Try running the engine then disconnect the battery, if the engine stops then the alternator is not putting out.
If it still runs, then check the voltage should be about 13.5 to 15 volts
Old Dec 5, 2011 | 04:51 AM
Boomtacoma01's Avatar
Nice score on the Xtra Cab!
Im kinda partial to those
Old Dec 5, 2011 | 05:52 AM
Ordering gears and locker(s) today, rear one for sure, but which one I pick will determine if I get both front and read. What do y'all think about the Spartan locker????
Old Dec 6, 2011 | 05:12 AM
Can someone answer thus question for me, which is most likely a srupid easy ansawer, what size is my front differential case, is it an 8" or 7.5"?
Old Dec 6, 2011 | 06:39 AM
Both of your 3rds are 8". IFS front diffs (starting in '86) are where you get into the 7.5" ring gear.
Old Dec 6, 2011 | 08:41 AM
Thanks, I wanted to double check before I finished ordering my gears, I thought it was an 8" , just had that second thought and wanted to make sure.
Old Dec 6, 2011 | 01:12 PM
RMP8080's Avatar
Hey, when ever happen with the battery/altenator problem?
Old Dec 6, 2011 | 04:58 PM
It was a actually more then just one thing i think, first the power wire from the altentator to the fuse box was old and basically falling apart. and then the ground from the altenator was not in the best of shape either, I found all this out then i pulled the + of the batter and the truck just died. so i replaced both of those and actually had all the fuses in the shop to just go ahead and change all the them out just in case one didnt have a good contact. once all that was done it worked 100% better. but it still is not enough to power anything more then what the truck has stock, so i went ahead and ordered the bracket to install a GM 1 wire. so i can now put on a 130 amp for free (perk of knowing people in the right place).
Old Dec 6, 2011 | 06:02 PM
RMP8080's Avatar
Glad you found the problem, good idea with the GM altenator. My build I'm putting V6 chevy so I need the bigger altenator anyway........thanks
Old Dec 6, 2011 | 07:51 PM
Think I am just going to stick with my 22RE and just do the stacked tranfercases 2.28 and 4.70. When i bought the truck it came with 2 spare transmisions and a spare transfer case to i am just going to do a good build up with one of the spare trannys and the tranfer case, got to get the 4.70 gears for one of them tho.
