How to identify your engine 20r/22r/22re block and head
Mods please make this a sticky. Kinda getting tired of cut and pasting from LCE's FAQ page. lol. Will add photos for those who don't know how to read.
Cylinder Head Identification
1975 - 1980 20R Cylinder Head
Round Intake Port
Round Exhaust Port
80/81 C.C. Chamber
Intake Valve Diameter 43mm
Exhaust Valve Diameter 35mm
Dual Row Timing Chain
Domed Pistons
Steel Rocker arms
1981 - 1984 22R Cylinder Head
Square Intake Port
Round Exhaust Port
82/83 C.C. Chamber
Intake Valve Diameter 44.5mm
Exhaust Valve Diameter 36.5mm
81-82 Dual Row Timing Chain
83-84 Single Row Timing Chain
Domed Pistons
Aluminum Rocker Arms
1985 - 1995 22R-22RE Cylinder Head
Square Intake Port
Pear Shape Exhaust Port
52/54 C.C. Combustion Chamber
82/83 C.C. Chamber (Turbo) Intake Valve Diameter 44.5mm
Dished Pistons
Engine Block Identification
1975 - 1980 20R Block
Deck Height 11.280\"
Stock Bore 88.5mm - 3.484\"
Domed Pistons
1981 - 1984 22R Block
Stock Bore 92.0mm - 3.622\"
Domed Pistons
1985 - 1995 22R-22RE \"Laser Block\"
Deck Height 11.090\"
Dished Piston
Round Intake Port
Round Exhaust Port
80/81 C.C. Chamber
Domed Pistons
Steel Rocker arms
Square Intake Port
Round Exhaust Port
82/83 C.C. Chamber
Domed Pistons
Square Intake Port
Dished Pistons
Domed Pistons
Domed Pistons
Dished Piston
It may be true but I'm not 100% sold on that yet, the 85 fsm makes reference to the 22R-EC engine under the electronic control section, I assume EC standing for electronicly controlled. Also the auto parts stores that I have been to only list parts for 22r or 22rec, no 22re. If the C in rec stood for California why isn't there a 22RC? Also, at least on the early 22re's they might actually have less smog stuff on the Cali models then the federal/Canada models, like no air injection tubes on the exhaust manifold.
There is a 22R-California model.
I am currently looking for a new Emission Control box for my 81 and guess what, it's year AND California specific. The motor may be the same, but the electronics on the carburetor aren't.
I'm aware of the fact that there are california emissions vehicles and federal/Canada models, I believe it's noted on the under hood emissions sticker. Having some different components I can understand needing a different brain, I'm just not sold on the C in rec being for Cali, I've seen the question come up a bunch but it always seems like a guess and not a fact. Why would the parts stores not have both 22re and rec options. Also online you will see people saying the C is for a bunch of extra Cali smog stuff, but from what I've seen there is not a bunch of extra smog stuff at least not on the early efi motors. Maybe the carbed models, I don't know?
This is getting off subject so let me ad that the early blocks, pre 85, also have the teq logo cast in the block on the exhaust side. As far as I know it's not on the later blocks.
Here's one for ya guys. I got a 22r. Single row timing chain. Exhaust ports are round but have a small hole above them. Carbon makes it look like the exhaust manifold was pear-shaped. The Pistons are domed. is this an 83 or 84 block when they change it to the single road timing chain. Can I put a 20r head on this block and change it to a double road timing chain. Ty for any help
I'm in the same boat I have a 22R and want to put a 20R head on it, like this page here..
http://tinyurl.com/kpsshnp
But im not sure what year 22r I have.. pre-83 or 84.. can I turn this into an EFI engine? Most of the identification on this post is not present on my motor.. help?
In parts stores only some parts are california spec o2 sensor and other emission related. in Canada Ive never had options as california is the hardest place to smog
That depends on the vehicle and year. Speaking only about the early 22re the emissions diagrams for federal/Canada models actually have more smog crap.
hello, new member here
Got a78 2wd pickup, the sticker on the valve cover is faded and the badge on the fender says its a 20r.
took the carb to a shop to get it rebuilt or a new one and the guy saw it and right away said, thats for a 22r, and sure, went back to browsing and yes, its a 22R...
how do i know which 22R I have, if in fact it is a 22R?
For reference showing one plug fits all..
http://www.lowrangeoffroad.com/toyota-22r-22re-22rte-genuine-oem-spark-plugs.html
