Easter egg hunt: where is the headlight fusible link on an 80 pick up
good question...i should figure out where mine is on my '81.
dunno how much the wiring changed between the 80-->81 but here are some pics of my 1981 wiring diagram that might help...
There is no headlight fusible link. There are 3 fusible links at the positive battery terminal that protect the Ignition switch circuits, Charging circuits and the Constant Power Circuits. The headlights are protected by a fuse circuit in the fuse box-left of steering wheel under the dash.
80 headlights only work all the time
I traced the power back to the headlight switch from the fuse after repairing the factory wiring but only have high beams.I know someone else has had this problem , what was the fix and does anyone have a schmatic isolating just the headlight circuit?
Head Light Relay power feed to fuse panel-Red, fuse panel to LH headlight-Red /White and to RH headlight-Red /Black. High Beam on headlights to Dimmer switch-Red /Green, Low Beam on headlights to Dimmer switch-Red /Yellow. Head light relay power feed to relay contact and coil + Red /Blue, Head Light relay coil - to Light Control and dimmer switches-Red /White. Note: The dimmer and light control switches switch neutrals / grounds not hot (12V+).
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
