Fuel gauge stuck on High/Temp always reads in middle?
My 94 toyota 4 cylinder fuel gauge is pegged on full. Yes I ran out of gas before I realized this. Now I notice that my temp gauge reads in the middle all the time(Even bone cold engine). When the key is off the temp gauge goes down all the way. The full gauge never moves.
Not sure if this is a related or both are separate problems. I put a new coolant temp. sensor on and no difference. Do not see any broken wires on top of tank either. Also took a hammer to gas tank to see if maybe the float was stuck.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
fuel gauge pegged on full is a grounded wire. Most likely at the tank connection. They like to rust out. See my build thread on how I fixed mine. Mine was a broken wire at first (always read empty) but noticed when I grounded one of the wires by mistake it read full.
And you sure you replaced the correct coolant temp sensor? I believe there is 2 or 3 on the 22re's.
This should be two separate problems IMO.
On to the fuel gauge. If I disconnect the plug at the tank the gauge goes down to empty. The wiring and plug have no corrosion or visible breaks. I was checking continuity and it doesn't seem like the hot wire is grounded. I'm thinking it's a stuck float. Will check on that next.
I did look at your thread pics on your problem. But I think it's in the float on m ine.
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Poncho0206
Jul 10, 2015 06:21 PM
