Fuel gauge stuck on High/Temp always reads in middle?
My 94 toyota 4 cylinder fuel gauge is pegged on full. Yes I ran out of gas before I realized this. Now I notice that my temp gauge reads in the middle all the time(Even bone cold engine). When the key is off the temp gauge goes down all the way. The full gauge never moves.
Not sure if this is a related or both are separate problems. I put a new coolant temp. sensor on and no difference. Do not see any broken wires on top of tank either. Also took a hammer to gas tank to see if maybe the float was stuck. Any thoughts? |
Originally Posted by 86toyota
(Post 51804726)
mine did the same thing it wound up being the float in the tank was stuck against the side of the tank, went in bent it strait and now its fine.
fuel gauge pegged on full is a grounded wire. Most likely at the tank connection. They like to rust out. See my build thread on how I fixed mine. Mine was a broken wire at first (always read empty) but noticed when I grounded one of the wires by mistake it read full.
And you sure you replaced the correct coolant temp sensor? I believe there is 2 or 3 on the 22re's. This should be two separate problems IMO. |
Originally Posted by xxxtreme22r
(Post 51804756)
And you sure you replaced the correct coolant temp sensor? I believe there is 2 or 3 on the 22re's. This should be two separate problems IMO. On to the fuel gauge. If I disconnect the plug at the tank the gauge goes down to empty. The wiring and plug have no corrosion or visible breaks. I was checking continuity and it doesn't seem like the hot wire is grounded. I'm thinking it's a stuck float. Will check on that next. I did look at your thread pics on your problem. But I think it's in the float on m ine. |
fixed mine. by sticking my hand through the fuel pump hole, reaching over and bending the float a lil. then grabbed the copper wiring to check to see if it was broke.
