3rd memeber help!
3rd memeber help!
picked up a new (to me) 3rd memeber. the ring has 37 teeth and the pinion has 9 making it a 4:11 and my old one has 41 and 10 making it 4:10.. also not sure how to tell if its out of a v-6 or not. could i runn this or will it cause a big problem
toyota OEM 4.10 has the 41/10 setup
Aftermarket gears are 37/9
You can use the 37/9 = 4.11 third with a OEM front 4.10
I've actually driven a 4.10 front with a 4.11 rear on pavement in 4wd for about a 1/2 mile. It's fine.
I did go back to OEM 41/10 4.10 beacsue the OEM gears were quieter than the 37/9 gears. My diff guy just couldn't set up the 37/9. He could set up the 41/10.
another question, im trying to install the spartin and the ring has to come off but it has this clips around the bolts. do i just bend them down and hammer back up when i put it back on or is there something else?
Read thru these.....: http://www.gearinstalls.com/
LittleUgly
15
Jan 2, 2020 01:30 PM
charlie_fong
Sep 27, 2015 10:06 PM
