92 P/U new long block many trouble codes
Hi new here need some help. 92 toy p/u 22re motor no air 5 spd. A friend blew a head gasket lots of water thru the cat and muffler. Significant amount in sump.I installed a rebuilt long block got it running after replacing both o2 sensors to clear a 21 code. It was running well I adjusted the valves set the timing checked the hoses. the truck ran well till today. It now has trouble codes as follows 21, 27, 43, 52. I am doing this as a favor. It is now long past favor.
I thank you in advance for any help.Crash
Hey dude, ...sorry you're dealing with the 'CODE GREMLINS'! .... I HATE EM! lol.
I would suggest not to keep spending your cabbage on parts, any further, before you dig a lil deeper.
Since you swapped in a new motor, it's quite possible that something is either not connected or some vacuum apparatus is missing a hose, whatever, and any of that can cause the ECU to go wacky and try to adjust things via the sensors, which then turn wackier by trying to adjust and therefore screwing even more up...(because those kinds of things are usually due to unmetered air or missing connection/faulty or compromised connection).
I would go through all the connections, meticulously, especially the EGR system, and try to rule out anything being unplugged/etc.. But first, clear all the codes as was suggested...
A 91-94(whatever it is) ECU in almost any yard will run you around 75$.... I'd try to swap in a known working one, first, if that's even the issue.
I was told that coolant through the cat and through the o2 sensors can ruin them does anyone have a correct answer for this one. When the owner brought the truck to me coolant was pouring out of the catalytic converter, muffler etc..
replaced engine with rebuilt long block, replaced o2 sensors, bad hoses, plugs and plug cables, dist cap and rotor.
Thank you for your help and replies
Crash
It ran well for several hours,cleared the codes many times they all come back.
Crash
Crash
Maybe the massive flow of fluids down there wound up steaming out the TPS and even caused a short in the ECU's No.10 and No.20 pins in the ECU or something like that?
MMA_Alex
25
Apr 18, 2017 05:07 AM
Poncho0206
Jul 10, 2015 06:21 PM
