castle nut slipping on pitman arm - relay rod
From: Zoo Jersey (where Toyota dealers charge $200 labor to replace 4 spark plugs)
My 87 4X4 pitman arm is wobbling at the relay rod - not at the bj (ball joint). The castle nut is rusted solid to the bj bolt. When I try to tighten or loosen the nut, the bj bolt spins with it.
I've tried pressing the pitman arm to the relay rod (jacking and clamping) with no luck.
My next step is split the castle nut, pull the pitman arm, inspect the relay rod and maybe replace both.
I'd rather just tighten the castle nut and be done with it. Anyone ever had this problem before?
Jcrawl94
10
Oct 24, 2015 04:34 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
