Failed Smog - Gross Polluter - Now What?
so my 82 22r failed smog at idle today.
heres the numbers...
first test
HC
max GP Measured
250 350 676
CO%
max GP Measured
2.00 3.50 6.01
second test after some adjustments
HC
max GP Measured
250 350 361
CO%
max GP Measured
2.00 3.50 4.01
at 2500rpm it is perfect
hc
max gp meas
200 400 60
co%
max gp meas
2.00 3.50 0.05
recently rebuilt carb. replaced almost all the vacuum lines. was running premium fuel, recent oil change and spark plugs.
any ideas what to check or change to make this thing pass? im open to all ideas
thanks!
first test
HC
max GP Measured
250 350 676
CO%
max GP Measured
2.00 3.50 6.01
HC
max GP Measured
250 350 361
CO%
max GP Measured
2.00 3.50 4.01
hc
max gp meas
200 400 60
co%
max gp meas
2.00 3.50 0.05
thanks!
maybe you just need a new cat, also i wouldnt run premium fuel. premium burns slower and if it doesnt get burned all the way, you engine will just dump the unburnt fuel out the exhaust creating higher HC.
a tune up and running some seafoam wouldnt hurt
Hmm gross polluter means you're not even close.... An '82 with CA smog problems is anything but "pennywize." This could be an pricey proposition...The Cat definitely needs attention after 30 years and check the smog pump, it's usually rusted out as well... I would start with the Cat and work backwards... They aren't cheap $200-250. Check your air lines thoroughly, make sure there's no false air..Retarding the timing, premium fuel will give you negligible returns, but it surely can't help..
Marlin Crawler has a company that sells after-market smog pumps, if you need to go that route....Or just get really friendly with your local smog station mechanic.. I'm feelin your pain, been there, Good luck,
its a federal emissions truck so there is no air pump. i dont know a ton about catalytic converters but it runs so clean at 2500 rpm it seems to me that the cat is functioning though a new one wouldnt hurt.
thanks to all for the input. ive got some ideas and will probably do a pretest before the next official test just to see whats up.
i'll let ya know how it goes.
This response is premature and most likely not the case, but if all other suggestions have failed one bizarre experience we had was a charcoal/purge canister that had somehow completely filled up with gasoline, yes in the liquid form. The engine was simply drawing fuel straight in through the vacuum system causing crazy high hydrocarbons. My guess was this resulted from topping off every tank all the way up the fuel neck somehow allowing the fuel level to stay higher than the purge tank.
Just thought I'd throw this out there. It was really a freaky deal!
BigMike
BigMike
You cuold sell it to me! I promise I would take good care of her.Just let me know a price.What I would do with a rust free toy!!!I do hope you get it figured out. What some stupid laws there.Sorry I think that johnny law.
BigMike
BigMike
BigMike
BigMike
Converter looks tired since it wll pass when hot and at operating temp and cools off for idle test. In Calif, do they run idle test first then high idle test second? Looks to me it just missed second time. Mixture screw adjustment? Gas in oil? PCV working? Needs cruise first. What's GP?
I thought you would be exempt from emissions testing in CA on a vehicle that old or that you could get an exemption. Street Rods are exempt in CA. In Pennsylvania you are exempt if you drive any vehicle under 5,000 miles per year and all Street Rods, Classic and Antique cars are exempt from emissions testing. My 1983 Toyota truck is exempt from emissions testing.
It REALLY blows chunks. Next year I'll have to smog my 1981 Hilux yet again even despite having a modern clean burning Tacoma 4cyl EFI engine under the hood. Based on the old law, 2012 is supposed to be my first year of smog exemption!! ............ it's too sad for us...
I'd love to up and leave this ridiculous state but I think they might notice if I take Dusy/Ershim, Rubicon, and the Hammers with me
BigMike
And old
article: http://www.catmbr.org/SB42pg.htm
Hey guys, so how do we get this going again? Look at this example letter to mail in to our elected officials: http://www.catmbr.org/sb42doc.html Why don't we start a thread and a big push on this throughout all the automotive forums and try to bring the rolling 30 year window SB42 law back??
In late 1997, a bill was passed by the California legislature making 1966-1973 vehicles exempt from the smog check program. This bill was called SB42 and was unanimously passed because of support letters sent in from people like you and me. Unfortunately, SB42 is in jeopardy of being repealed due to Smog Check II's failure to bring emission levels within federal standards. Once again, the California Air Resources Board is wrongly blaming old cars for smog problems.
And old
article: http://www.catmbr.org/SB42pg.htmHey guys, so how do we get this going again? Look at this example letter to mail in to our elected officials: http://www.catmbr.org/sb42doc.html Why don't we start a thread and a big push on this throughout all the automotive forums and try to bring the rolling 30 year window SB42 law back??
