3VZE Rod journal tolerances
Old Jun 11, 2011 | 09:20 AM
DrCreosote's Avatar
I had a rod knock in my 4Runner w/3VZE and found a bad bearing. Checked the journal and it is .023 out of round. Is this within tolerances? The surfaces feel good and wear is even side to side, no bad scratches or gouges.
ThanX,
DC
Old Jun 11, 2011 | 11:14 AM
scope103's Avatar
http://personal.utulsa.edu/~nathan-b...ine/9cylin.pdf (page 52) says maximum clearance is 0.0039 inches.
Old Jun 11, 2011 | 12:06 PM
saved's Avatar
ThanX,
DC
Absolutely not. If you are talking about a crank journal .023 out of round you need a new (or rebuilt) crank. If you are talking about the rod inside dia. where the bearing is fited into being .023 out of round that too is way out and you need a new rod. I would check them all if one was that bad. Both the crank and the rod journals need to be round. With that much out of round it is surprising you had any oil pressure. Also if the crank is good be sure that the crank is not a regrind if you only replace the bearing so that you get the right size bearing.
Old Jun 11, 2011 | 01:45 PM
DrCreosote's Avatar
Good deal. I thought that was a dang big number to overcome, but what I thought to be true was cast into doubt because I listened to someone else. I'm glad there are more knowledgeable people here and I was expecting to rebuild the thing anyway so I'll just stay the course.
ThanX
DC
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Kamaloha
Oct 16, 2015 05:13 PM
