help please yota bros! A link or form! 95 4runner brake rotor
Old May 10, 2011 | 04:43 PM
offroad1990's Avatar
I gota change my front left rotor out, on my 95 3vze 4runner but not to sure how with this one, any forms or info with pics at all??,, thanks, jesse
Old May 10, 2011 | 05:27 PM
kaner07's Avatar
your gonna have to take everything off the axle shaft. take the dust cap off the end. Remove the 8 or so bolts that hold the end cap on and slide it off. then there is some clips and large nuts and lock clips that you need to remove then you should be able to slide the rotor off. then you need to seperate the rotor from the hub by taking the bolts on the back out. then you will probably need to beat them apart with a hammer and a chisel. hope this helps good luck
Old May 10, 2011 | 06:25 PM
toyota4x4907's Avatar
http://www.ncttora.com/fsm/1990-1995...es/repair.html
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
ptb12
Jul 5, 2015 01:49 PM
