Weber 34 dgec on a 22R
I was wondering if anyone knows what jets to use for a weber 34 dgec on bone stock 22R at around 600-1000ft elevation. It runs really good but it seems to be sucking gas, does anyone have a similar setup?
did you get a fuel pressure regulator for it? there only supposed to run i think 6 psi and the fuel pumps put out alot more than that i get good milage but idk if its the regulator or because my fuel pump was leaking so i replaced that too
I didnt get a regulator because most of the setups I've seen and read about, their not using regulators. But I havent seen alot of 34 dgec's I was just assuming the stock fuel pump was fine.
i have a 34 on my 87 and it was running extremely rich at idle, i called weber and had them send me 2 smaller idle jets and its 10x better now..i believe i was running a 50 and 55 from the factory and they sent me a 40 and 45?
buckz6319
Aug 5, 2017 03:50 AM
Toys4parts
Sep 26, 2015 01:56 PM
