HILUX SURF ln130 2.4 litre turbo diesel part number thread
didnt see too much when searching here.. i think YOTA TECH needs more toyota diesel love.
here is a list of the part numbers i have collected.. during my 3 years of toyota diesel ownership.. i like to use OEM toyota parts and like to keep filters on hand.
NGK GLOW PLUGS
y-188t-1
these numbers now are all OEM TOYOTA NUMBERS
RIGHT HAND DRIVE IDLER ARM
45490‑39375
Timing belt
13568-59066
Timing idler #1
13505-54021
Timing idler #2
13503-54030
Water pump
16100-59257
Crank oil seal
90311-42026
Cam oil seal
90311-32018
OIL FILTER
90915-30002
Alternator Belt uses double belt on alternator and waterpump
90916‑02209
newer number 90916-02211
Power steer/Vane pump belt
99332-00830
A/C belt
99332-01260 or 99332-01265
Air Filter - 17801-54060
Fuel Filter - 23303-64010
NGK GLOW PLUGS
y-188t-1
45490‑39375
Timing belt
13568-59066
Timing idler #1
13505-54021
Timing idler #2
13503-54030
Water pump
16100-59257
Crank oil seal
90311-42026
Cam oil seal
90311-32018
OIL FILTER
90915-30002
90916‑02209
99332-00830
A/C belt
oops forgot these parts are for ln130 hilux surf 2.4 litre turbo diesel engine...
toyota canada had a 2.4 non turbo till 1986 so some parts i can get local some parts i have to order.
that pipe is crazy expensive slacker.. i dont know if you still need it as its years ago but i used a pipe that my mechanic uses to exhaust outside it has worked for a year... but my friend is going to thailand next week and going to ship me some parts so if you need let me know!
while I got ya .. is the battery on the Left hand side on the surfs ?
Power steering??
NGK GLOW PLUGS
y-188t-1
45490‑39375
Timing belt
13568-59066
Timing idler #1
13505-54021
Timing idler #2
13503-54030
Water pump
16100-59257
Crank oil seal
90311-42026
Cam oil seal
90311-32018
OIL FILTER
90915-30002
90916‑02209
99332-00830
A/C belt
NGK GLOW PLUGS
y-188t-1
45490‑39375
Timing belt
13568-59066
Timing idler #1
13505-54021
Timing idler #2
13503-54030
Water pump
16100-59257
Crank oil seal
90311-42026
Cam oil seal
90311-32018
OIL FILTER
90915-30002
90916‑02209
99332-00830
A/C belt
the part number for the power steering? Where do I go to buy these parts??
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
