HILUX SURF ln130 2.4 litre turbo diesel part number thread
didnt see too much when searching here.. i think YOTA TECH needs more toyota diesel love.
here is a list of the part numbers i have collected.. during my 3 years of toyota diesel ownership.. i like to use OEM toyota parts and like to keep filters on hand. :readit: NGK GLOW PLUGS y-188t-1 these numbers now are all OEM TOYOTA NUMBERS RIGHT HAND DRIVE IDLER ARM 45490‑39375 Timing belt 13568-59066 Timing idler #1 13505-54021 Timing idler #2 13503-54030 Water pump 16100-59257 Crank oil seal 90311-42026 Cam oil seal 90311-32018 OIL FILTER 90915-30002 Alternator Belt uses double belt on alternator and waterpump 90916‑02209 newer number 90916-02211 Power steer/Vane pump belt 99332-00830 A/C belt 99332-01260 or 99332-01265 Air Filter - 17801-54060 Fuel Filter - 23303-64010 :drink: |
oops forgot these parts are for ln130 hilux surf 2.4 litre turbo diesel engine...
toyota canada had a 2.4 non turbo till 1986 so some parts i can get local some parts i have to order. |
currently looking for # 17881-54270
air intake tube #3 . ( flex tube from air filter box to air intake tube) this is for charity , so any help appreceated . |
that pipe is crazy expensive slacker.. i dont know if you still need it as its years ago but i used a pipe that my mechanic uses to exhaust outside it has worked for a year... but my friend is going to thailand next week and going to ship me some parts so if you need let me know!
Diesel love!
Happy to see some more righties out there. I'm working for the money to dump into my Hilux Surf. It might be parked a while longer but I'm going to do my research while I try to be patient.
Originally Posted by bigt
(Post 52042692)
while I got ya .. is the battery on the Left hand side on the surfs ? . |
Originally Posted by slacker
(Post 52045344)
no , I ended up buying a new one , and donating it to "chrime stoppers" (this was the Charity)
mine has 2 batteries one on each side. love your new trekker build!
Power steering??
(Post 51711753)
here is a list of the part numbers i have collected.. during my 3 years of toyota diesel ownership.. i like to use OEM toyota parts and like to keep filters on hand. :readit: NGK GLOW PLUGS y-188t-1 these numbers now are all OEM TOYOTA NUMBERS RIGHT HAND DRIVE IDLER ARM 45490‑39375 Timing belt 13568-59066 Timing idler #1 13505-54021 Timing idler #2 13503-54030 Water pump 16100-59257 Crank oil seal 90311-42026 Cam oil seal 90311-32018 OIL FILTER 90915-30002 Alternator Belt uses double belt on alternator and waterpump 90916‑02209 newer number 90916-02211 Power steer/Vane pump belt 99332-00830 A/C belt 99332-01260 or 99332-01265 Air Filter - 17801-54060 Fuel Filter - 23303-64010 :drink: the part number for the power steering? Where do I go to buy these parts?? |
Originally Posted by Espitiahilux
(Post 52407560)
