What are the most commoin 1st gen 4runner brake upgrades?
So I was on a budget and desperately had to do my rear brake shoes last week. Got everything apart and found out I need new wheel cylinders and drums also. I slapped the 10 dollar shoes on there and put em back together.
I also know I need new brake pads up front soon, my calipers seem to be sticking, it pulls when braking, and a leaky master cylinder to top it all off.
I looks like I might be needing almost a complete brake component overhaul.
But why replace them with the same kind? Like I remember reading something about being able to use V6 calipers up front? Or v6 master cylinder?
What are all the mods out there?!?! I work for a parts store, so my prices are awesome on almost everything
, and we mostly sell Raybestos, centric, and can get all the napa stuff. Thats why I figured I could spend the little extra money and get new parts.
"v6" calipers, "v6" Dual diaphragm booster and a 1" "v6" master cyl. I keep "v6" in quotes as most later model 4cyl got the same stuff. IMO don't use a 1" master on a stock single diaphragm booster, mine resulted in a harder feeling pedal till I put in the dual. Also I personally wouldn't use the v6 calipers with a non 1" master. What I am not sure about is whether or not the v6 calipers require a different rotor then stock. I wanna say no, but I could be wrong as I haven't upgraded my calipers yet, just the booster and master. The master I got from autozone and was meant for a v6 T-100. The booster I pulled from a junk yard from a 3.0 95 pickup.
Im not the most knowledgeable, weekend mechanic, are these complicated to do?
see my sig for rig info. and unless the previous owner did them I am almost certain you do not have the above mentioned stuff.
The hardest part is bleeding the brakes when changing master cyls. In which I hate, I never get it right the first time. Even with doing the required bench bleed on the master.
yeah, I was trying to understand how the whole bleeding the brakes works and everything. That I will probably have a mechanic buddy help me with.
Hey, I grew up outside of Bangor, PA. Lower Mount Bethel township. I miss that area. I recall Wilkes-Barre, PA not being to far?
Yes, you need to replace the rotors to go along with T100 calipers
https://www.yotatech.com/forums/f77/.../#post51108105
I put a whole bunch of brake info in one post here: http://www.expeditionportal.com/foru...55&postcount=5 <- this is pretty much the whole shebang
FWIW - 1" master cylinder with stock calipers is fine, just makes the pedal a bit firmer & my brake pedal is OK without the dual diaphragm booster (couldn't fit it on my truck even if I wanted to)
Corax I wasn't mentioning the t-100 calipers but just between the 4cyl and 3.0 style calipers. I had actually forgot about them as an option. A little more work I guess, but a better option.
haa yeah I know it should be easy. But for some stupid reason it kicks my butt. And I always bleed in the proper sequence etc etc and use the one man bleeder kit as I am 90% of the time doing it myself.
Here is the list of caliper casting marks that I found and posted on another forum <- link
Here are the '88 4runner rotor specs used with the S12+8 cast caliper:
# of Bolt Holes:6
Bolt Circle Diameter:5"
Diameter:11.375"
Height:2.535"
Maximum Lateral Runout:.004"
Thickness When New:.79"
Discard Thickness:.709"
Center Hole Diameter:3.942"
here are the T-100 4wd rotor specs used with the S13WB cast calipers:
# of Bolt Holes : 6
Bolt Circle Diameter : 5"
Brake Rotor Diameter : 11.45"
Brake Rotor Discard Thickness : .91"
Brake Rotor Thickness New : .99"
Center Hole Diameter : 3.94"
'93 4runner V6 rotors:
# of Bolt Holes : 6
S13WB caliper with stock '88 4runner 4 cyl rotor
I went into work and checked the parts in out computer system(same as NAPA online). Yep they are the same
thank you for all the clarification. Next weekend I might begin tackling this. I might do a write up, since there weren't very many when I was searching(beside the links posted here)
I'm going to assume that with different calipers and rotors, I will also need the bigger brake pads?
Next step is to do some research on rear disc brake swap. I don't want to spend 400 dollars on the kit, so Im going to find out if I can get the brackets alone and find out what type of vehicle the calipers, pads and rotors go on
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
