Solutions for reducing rear-end sag
Good Day Folks,
I am curious about the measures for reducing sag while transporting my dirtbike via a hitch mounted carrier. The carrier weighs 30lbs and the bike weighs 230lbs. I'd like to avoid installing stiffer springs if at all possible.
Any ideas?
Thanks Much!
G
Any ideas?
Thanks Much!
G
if you have rear leaves, do a search for "Zuk mod" or something similar.
http://gearinstalls.com/dc.htm
No you do not remove the rear springs...at least with these. I believe your ride quality would reamain stock untill you bump up the psi for load carrying.
http://www.suspensionconnection.com/...con/4123T.html
I haven't heard anything good about those air bag systems. My ol man went with air bags in his 06 suburban since he is an electrician and was always carrying a heavy load in the back all the time and he has been having nothing but problems with the things. may it was just the brand he went with, im not sure. I put a set of the OME 906's in the back of my 96 runner and i carried a load of about 1000 pounds of wood pellets in the back one day last fall. it drove great i found.
Use a helper bag system with on board air. There are many universal kits on the market now. Some modifactions will be needed to support the bags and make sure the bags will not rub on anything or it will end up with a hole in it. Make sure you don't have any leaks on the fittings or it will be useless! Replacing your springs with bags would be cool but is not practical due to blowing a bag and riding on your bump stops. Just my 2 cents hope it helps.
Air shocks vs. air bags
I have had both air bags and air shocks on my 96 4Runner. I used the air bags with a load controller (on-board air from Air-Lift) for some time, but it still had the "Sag" like most 3rd gen, even when I pumped them to 35psi (max pressure). I used them for a long while to keep it from slamming into the bump stops when I towed. I usually keep about 200-250 lbs of equipment in the back of my vehicle (right over the rear wheels) and it helped out there as well. After about 75k miles one of the bags finally blew. I ran without anything for about 5k miles, but I had to do something. I went ahead and got a pair of Monroe MA700 shocks and forced those puppies onto the lower shock mount and got two 1/4" to 1/8" pressure fit connectors. Now, I can run my air shocks from 20psi to 100psi right from my drivers seat. And it does make a difference when driving and now my "sag" is gone! I plan on putting some OME890s on as well, but for now, this works out really well. Haven't towed yet, but think I should have no problems.
ashamsuddin
17
Jul 22, 2024 03:59 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
