Gathering info for the 22r - 5Vzfe
Old Apr 5, 2011 | 05:18 PM
slacker's Avatar
so I have a 90 4Runner with the 22re in it ..
i'm going to swap in a 3.4L W/MTM
I know I have to do the engine mounts , I'm going to use the 3.0L .. + have the most of the wiring and cooling info. I need ..
wondering about the tach. ?
any info appreceaed
Old Apr 5, 2011 | 08:56 PM
dntsdad's Avatar
Not sure on a mod to change the 22re tach. It may be the same as the 3.0 as far as I know.
If it was me I would just grab a 3.0 tach from someone parting one out and then you know the resistor mod would work as described in my thread and many others.
Old Apr 6, 2011 | 05:50 PM
slacker's Avatar
thanks .. I read your install post .. great work by the way .. i'm thinkin' this will work as well , but I was hoping to hear for an "actual" fix .. not to many people have done this though !!
Old Apr 6, 2011 | 07:25 PM
jasond's Avatar
I did this on my 92 22r/5vz truck, just adjust the rheostat while watching the data list on the scan tool - thats what I did and it works just fine. No need to buy another tach or solder anything on to it, it has the adjustment part built right in. I pulled out the speedo when I was doing this so I could leave the tach hooked up and plug in the instrument cluster and still reach the rheostat.
Old Apr 7, 2011 | 12:21 AM
vital22re's Avatar
totally a bro
Thank you for posting. Good to know there is a fix for the 4cyl guys.
Old Apr 8, 2011 | 08:38 PM
slacker's Avatar
so the rheostat is right on the back of the tach cluster ? .. and what scan tool are you using ?
thanks for your help
Old Apr 8, 2011 | 08:50 PM
dntsdad's Avatar
Good to know
Old Apr 9, 2011 | 07:01 PM
jasond's Avatar
I was using a toyota scan tool, but pretty much any decent scan tool should be able to show you this as long as it has a data list function. (not the cheapie $30 units)
The rheostat is built into the tach. It takes a tiny flat head screwdriver (if I remember correctly). Once you take out your instrument cluster and take out the speedo you should be able to see it. If not take out the tach also and examine it up close, then reinstall just the tach and leave the speedo out until you get the tach dialed in right.
Old Apr 9, 2011 | 10:01 PM
hamish_18's Avatar
wish the 3.slow tachs had that! you guys are lucky!
Old Apr 10, 2011 | 08:00 AM
slacker's Avatar
sweet .. thanks much
Old Sep 9, 2011 | 05:40 PM
slacker's Avatar
so just to refresh the info .. as to pertaining to my install ..
just adjusting the pentiometer or rheostat did NOT work .. I had to also do the resistor mod as well ..
resistor mod , and adjusted the rehostat to correct RPM .. worked and works great ..
Higbee89
Aug 27, 2015 06:52 AM
treadonmenot
3.4 Swaps
Aug 22, 2015 12:40 AM
ChiefTetlow
Aug 10, 2015 04:19 AM
snosurfer
Aug 5, 2015 03:55 PM
Cplmike
Jul 8, 2015 08:47 PM
