A-Frame the rear shocks ?'s
How do u A-Frame your rear shocks?? And what r the pros and cons of it?? Seems like a good mod i would like to do later on after i get my longer shocks.
Thanx
Thanx
Well.
You have to start with new shock mounts on both the axle and frame..
And pros: Better flex (pretty sure, atleast, dunno)
Cons: More body roll, stiffer ride (shocks fighting pressure to move inward when axle moves up and down parallel to the ground)
you'll also need to weld in a new crossmember, for the shocks to mount to
Simple geometry.
IF a shock is directly up and down, for every 2 inches of axle travel, you will use 2 inches of shock travel.
IF you pitch it inward, you can install longer shock bodies (longer stroke) yet due to the angle for every 2 inches of axle travel, you will use less than 2 inches of shock stroke. Therefore if you improve your axle travel, this will allow you to fit shockes capable of handling the stroke.
However this adds leverage to the dampening affect, therefore you need to use a stiffer shock to equal a standard shock that is mounted directly up and down (if you want to match the dampening affect that is)
Some do state that it fights body roll however that is very minimal if measurable at all.
IF you have not increased the axle movement then dont waste your time, energy and money on mounting the top of your shocks inboard.
Check out 4crawlers write-up, it should answer most of your questions
www.4crawler.com/4x4/4R_suspension-III.shtml
Only issue I see that I don't like is it looks like it somewhat interferes with the e-brake cable and 1 or both brake lines will need to be re-bent.
But.... I wouldn't do this on a crossmemeber that is wielding signs of rust and rot like mine. lol.
Yotadawgjr
10
Aug 23, 2015 10:51 AM
terminator
Jul 27, 2015 07:13 PM
icentropy
Jul 14, 2015 10:23 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
Jul 9, 2015 02:34 PM
Thanx again!!
