ground straps
ground straps
Ok guys I searched and wasn't able to find the correct answer.
I pulled my motor out and have installed another motor. This is been my first motor removal/install but its gone pretty good IMO. Problem I have ran into is the ground (I'm guessing) that is on the same lead as the starter wires. Where does it go. Where is the correct placement.
Also, at the end of the fuel rail I have a hose that I have yet to connect as I have no clue where it goes. Gas leaks out when u turn the key if that helps any...end of fuel rail closest to cab.
Auto transmission guys. The a340h where is the correct routing of the trans cooler lines. Above motor mount?
It is a 90 Toyota pickup 22re auto ext cab 4x4
I don't have access to internet ATM I can only use my blackberry so the more help the better. TIA.
Ok then ill get that checked out pronto as I'm going to try and fire her up and get her moving under her own power again. just gotta get these few little things situated.
Ty for the help
Ty for the help
the ground wire on mine the big black wire connected to the motor mount bolt to the motor, and the cooler likes where under the motor mount, mines the v6 but would thing they would run both the same way.
this is with a manual trans, but the engine grounds should be in the same places
https://www.yotatech.com/forums/f116...-guide-194413/
live4soccer7
May 11, 2016 06:52 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
charlie_fong
Sep 27, 2015 10:06 PM
