where the heck is my trans fill plug?
I see the drain plug on the bottom of the transmission, but where is the fill plug at?
It is a 87 4runner 22re 5 speed. w56? im not sure of the model
Usually driver's side, next to the reverse light switch. Which is the switch? The only thing on the side of the trans. with wires hooked to it.
Red = fill
Green = drain
Blue = reverse
Red = fill
Green = drain
Blue = reverse
Typically no separate vent on the earlier t-cases, they vent through the shifter base. If the boots are torn up, especially the inner most one that covers the base of the shifter, water kicked up from the road can get in from above. Happened to a buddy's rear case.
chaz1951
Aug 11, 2011 02:06 PM
