Removing Rear Differential Carrier
1998 4Runner with locking differential
I am attempting to remove the rear differential carrier in order to rebuild (the howling has finally gotten the best of me)
First off it seems that the actuator is fried. When I push the button on the dash the light blinks???
I have the right axle off but cannot get the rest of the carrier out...something is stuck bad. Perhaps the shift fork?
I can hear the actuator motor turning when powered however nothing happens!! Any ideas on how to get the carrier out?
Thanks,
Mike
Thanks,
Mike
you can also download the FSM from the link in my signature.
When pulling the rear third be sure to unhook the E Brake cables and your brake lines.
Some people will just pull the axles out far enough to get the carrier out and let the axles rest on the axle seals...if I do that I end up doing a rear axle seal later on...
Thanks,
Mike
Thanks,
Mike
I have both axles completely out and the fork does not want to budge... any ideas on how to get the actuator out?
not to thread jack but I have the same issue with out the locker...just an open diff. both axles completly out. I can pry at it and the bottom will move (1/8") but not the top. It's is acting as if it is welded on. Any tips?
jerusry
Oct 19, 2015 05:28 PM
icentropy
Jul 14, 2015 10:23 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
