W56 Transmission Problems
Fist off I have been reading Yota tech for a very long time and a lot of the advice on here is great. I felt it was time to get to know some of you guys and take the time to Register and see if I could return the favors so many of you have granted me......That being said.....I have an 88 model (pickup) with the 22re with the w56 5 speed.I bought the truck to turn into something akin to so much of what I see here.It was making the common growling sounds that they do after low maintenance so i decided to pull the tranny and stick in the new bearings ( most common prob ) upon disassembly i found busted gears , broken bearing races , missing synchros ,hardly any fluid at all , and none of the snap rings were there anymore. SOOOO.....off to the scrapyard with that one ! now my question is ( besides a martin ) where is the best place around KS to find Toyota parts ? I need one asap and dont have the availability of a donor truck.I do have an 87 4runner,but Id rather not gut that one to build this truck.Any help would be much appreciated and hopefully returned in the future.I am new here so if I posted this in the wrong place ...
..Sorry !
..Sorry !
Just watch your posting. The title has punctuation in it covering a fowl word, at least I assume. The moderators don't tolerate that very well. In the future try to use the word you want rather than the way you put it.
Just trying to help you out.
Thanks Toyman , However ,I ran across a 120000 mile forward shift w 56 ,T-case,Driveshafts and crossmembers late last night for 200 bucks.All I have to do now is change the tail housings and t-case shifter rails ( top shift conversion ) and ill be set.
WTB[PacNorWest]: w56 c manual trans with t-case and drivelin
89hilux1
Jul 19, 2015 01:32 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
