1998 Toyota 4Runner Timing Belt and Water Pump Replacement
Old Jan 10, 2011 | 03:07 PM
cheart's Avatar
I just recently had the timing belt and water pump replaced on my 1998 4Runner (108K miles) and was wondering if there was anything else that should have been replaced? My cousin was advising that I also replace the crank shaft and cam shaft oil seal, as well as the oil pump oil seal. I want to make sure that the mechanic is not taking me for a ride, considering how much it cost to have it all done.
Old Jan 10, 2011 | 04:47 PM
Noil's Avatar
I just replaced the timming belt in my 97 4 runner (before its recent bout of not wanting to work) and all we replaced was the water pump and thermostate and termostate gasket. Replacing the crank and oil pump would seem unnecessary to me.
Old Jan 10, 2011 | 05:03 PM
TheDurk's Avatar
There are two schools of thought on the cam and crank seals. Some feel they should be replaced. Others, myself included, think it's only necessary if they are leaking, especially if it´s the first belt change. I just did my TB/WP at 120K, and I bought the seals, but I left them in the spares box when the originals looked fine. I´ll probably use them next time I go in there if I´m north of say, 180k.
Oil pump seal? I have no idea.
Old Jan 12, 2011 | 10:36 AM
hnugen's Avatar
If you are not doing all the work yourself, get it replaced all at once so you dont have to deal with it later. Make sure you are getting OEM parts, most importantly the seals.
Why arent you doing the work yourself? Changing the timing belt and pump pump on the 5VZ is about the cleanest and easiest timing belt I've ever done.
Old Jan 12, 2011 | 02:39 PM
Whiplash Willy's Avatar
What about the 2 idler pullys? I have 108k on my 2001, and am unsure if I should do those or not, since they are $50 a piece!
Also, you don't want to reuse your old Crank Bolt, once it has been torqued. Make sure you get a new one.
Old Jan 12, 2011 | 02:48 PM
85gijunk4x4's Avatar
i think you should go with new seals, its not a priority, but when you get a chance.
even though they arent/werent leaking, working around them may have disturbed them, so maybe they will begin to leak.
Old Jan 12, 2011 | 08:30 PM
Man4God's Avatar
I want to know this too. But I have 185K. I had an Isuzu Rodeo that had an idler pulley go and it was a little scary. What is inside of them that goes bad? Bearings?
Paul
Old Jan 12, 2011 | 08:35 PM
Elton's Avatar
188k is all my factory water pump would do before it seized up.. everything was dry cam seals look fine i got a nice kit off ebay with every and i did all the work mostly my self it took a day but felt good i just saved like 500 bucks
Old Jan 13, 2011 | 08:48 PM
cheart's Avatar
Unfortunately, I'm not that mechanically inclined, plus I don't have all the necessary tools to do major work. Thus, I have to painstakingly try and find someone who will not take me for a ride and who I can trust to do the job.
Old Jan 13, 2011 | 10:03 PM
aa1911's Avatar
you don't need any special tools other than something to hold the CS pulley, I just did mine (thanks to a shop not torquing things to spec, mainly the CS pulley bolt, which you need to replace btw...) and I'm no mechanic, not hard at all.
Use a Toyota t-stat and crank bolt for sure, I highly recommend a Toyota timing belt too just because of the marks and ease of installation.
just my .02....
Old Jan 14, 2011 | 07:33 AM
Mauzer's Avatar
I recently got a kit from Volkstoy Motorsports that included everything (belts, timing belt, idler roller, tensioner roller, tensioner, seals, thermo, thermo o ring, water pump and gasket) for $240 shipped!
Old Jan 14, 2011 | 08:53 AM
4ever4running's Avatar
That is an awesome deal!! Sorry to hijack...but have you installed/replaced everything yet? I am at about 180K and I need to replace all that stuff and I would like to learn how to do it myself, as well as save some $$$ so I would like to watch/help you replace yours and get some help with mine. I just don't know enough to feel comfortable to do it myself, and I don't have all the proper tools. I would be more than happy to pay you for your time/help and buy the
Old Jan 14, 2011 | 09:22 AM
Mauzer's Avatar
I just ordered the kit, I plan on going up to College Station to see my buddy Rob b/c he's done it before and has the special tool for the CS. If I feel confident enough after doing it with his guidance I'd be glad to help.
Old Jan 14, 2011 | 09:52 AM
Thanks! I acually sent Rob a message asking him for help too...I will probably work with him to get something fabbed up for my Jerry Can mount that I talked about in the other thread so I asked him if he had any experience with it...Maybe we could do both of ours at the same time with Rob's help...
Okay no more hijacking, back to the original topic.
Old Jan 14, 2011 | 10:05 AM
yotarob2005's Avatar
I was thinking that it might be too much for one day, but if you 2 think we could be organized enough about it we can do try to do both at the same time. Just keep the part piles seperate and the tools organized. I know we can fit them both in the garage at the same time and I can prob talk Sam into coming and lending a hand aswell.
Old Jan 14, 2011 | 10:23 AM
J2F42C's Avatar
With the $240 Ebay TB kit....
I'd replace the Motorad thermostat with an OEM (Kuzeh). I had a Motorad fail on me once (open) only days after out of the box in another vehicle. Otherwise it is a great, great deal on that kit.
Take some pics of the install and post them when done......
Old Jan 14, 2011 | 11:01 AM
Mauzer's Avatar
Def too much for one day (especially the way we work Rob)
Thanks for the heads up, Volkstoy warranties all the parts but I may pick up a spare. Never hurts to have an extra t-stat
Old Jan 16, 2011 | 12:41 PM
Just_Me69's Avatar
I replaced mine with the Volkstoy kit yesterday at 157K. All original miles. The tensioner bearing was howling a little. Also, that same pulley had melted parts of the belt on it. The water pump was seeping as well.
Old Jan 16, 2011 | 05:13 PM
moneyshot's Avatar
Just a heads up, This tool is a must have for the 3.4 timing belt. I worked with the guy who sold this tool idea to Snap-on, it pushes against the water pump and tensioner so you can install the pin to keep tensioner back(huge time saver). I think they go for about $50 from your tool dealer.
Old Aug 8, 2017 | 08:56 AM
chrisl7678's Avatar
I have a 1998 toyota 4runner and I recently replaced the timing belt, hydraulic actuator, and tensioner that sits on top of the hydraulic actuator. While replacing the tensioner, I would not tighten down but just started spinning when the bolt was all the way in. Is this normal or should the tensioner bolt be tight? Thanks to anyone who can help.
