2wd 2.4 22re waterpump replacement help!!
If you have any advice, tips, knowledge or fascinating wisdom that can help a young man like me please let me know. im trying to replace my water pump and so far ive taken the fan shroud out....aaand thats about it. what to do nextt...i'd like to do it on my own without a mechanic, mechanic will be my last resort. (tryin to save money, hope you can understand.) anyways if you have any pointers it is MUCH appreciated. THANK YOU AND HAPPY HOLIDAYS!!
Take the belts off next. Drain the anti-freeze. Removing the radiator isnt necessary, but it helps lots. You already have the fluid drained, so it only 4 bolts and 2 hoses. Beware, the lower hose is probably rusted onto both the radiator and the metal piping! Then remove the fan (4 bolts). Now, take a piece of cardboard, as you are taking the bolts on the water pump out, put them in the cardboard (like through holes) in the orientation that they are on the water pump. Like the top one, put towards the top of the cardboard.
MMA_Alex
25
Apr 18, 2017 05:07 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
22r, 22re, 2wd, fan, instalation, install, installation, pump, removal, remove, replace, replacement, replacment, water, waterpump
