fan and water pump stuck together
having to replace the water pump in my 85 runner. put the pulley, water pump, and fan together then realized i need the water pump separate to install it but they wont come apart. what the hell!
Some times the fan clutch is a tight fit on the water pump shaft, remove all of the bolts and use a flat blade screw driver and a small hammer and a few light taps and they should seperate.
