oil dipstick location...
i have an 99 tacoma 3.4 trd OR
and it has a dipstick hole on the driver side right behind the oil filter...
can i use this hole instead of drilling the plug out on the pass. side?
Passenger side?
I bought a bung with a hole in it for the dipstick tube and just swapped them out. Then tapped the original with M14 tap, screwed in a bolt with some RTV done. Pics on my build thread.
:wabbit2:
:wabbit2:
murphyz the oil dipstick is already in the correct location if it is BEHIND the oil filter. if its in front as in, it goes through the oil pump housing, then you would need to change it. Though off subject does anybody know why you even have to worry about this in the first place??
Yup!! Different sumps
Mine had the hole at the front of the block. All I did was cut the original 3.0 dipstick down about 8 inches and used it to plug the tube. Why go to the trouble of all that fab work, tapping and sealing if you dont have to? Admitted, it looks cleaner without the additional useless dipstick.
My hole is behind the oil filter... But... I'm running the 3.0 pan, pickup tube and baffle. I'm "hoping" I'll be okay... I'm figuring I'll just put the correct amount of oil in it and see where it ends up on the dipstick. If it's off, I'll just engrave the dipstick with my new level basically.
Not sure which dipstick I've got to be honest... The motor was previously in a older pickup but was running the T100 3.4L pan and setup. I had to switch to the 3.0 setup though because of my steering setup clearance issues. I'll make sure to pull the dip stick from my old engine before the scrap guy takes it. I'm not letting the old motor disappear till I'm 100% sure the new setup is up and running correctly. Even then I'm going to strip all the accessories I can and ebay them or something...
Thanks for the reply! I appreciate it!
This led to me having a direct drop-in without any pan/disptick/pickup/baffle changes whatsoever. (I never even took the pan off it).
