Big 3 ?? Truck wont start
I'm replacing my alternator with a 130amp. I replaced the wire going from the alternator to the side of the fuse in the fuse box under the hood. I left the original wire inside the factory harness but cut the ends off and wrapped them with tape. I went to start the truck and it wont turn over at all. The head lights work and that's it.The dash only shows the charge light and 4wd light. I have also checked all the fuses under the hood and under the dash and they checked out OK. Am I over looking something or am I forgetting something? The truck started and ran fine yesterday.
Edit: I have not replaced the alternator yet only the wire. I also replaced the 100amp fuse with a 120 amp fuse.
just checked that also. Battery has 12.7v DC and I have power on both sides of the new fuse I put in.
What I don't understand is why the truck wont turn over. I highly doubt the starter is bad.
After looking into it further. The coolant hose that is above the alternator is leaking on the old alternator. I wonder if that has something to do with my problem. I'm going to replace it tomorrow and swap out the old alternator and see what happens.
It's worth a shot. I'll see if i can't think of something else. Sorry i can't help more.
It's no big deal is has to be something easy to fix. It worked before I put this new wire on and it looks like the coolant has made its way into the alternator. I still don't know why that would cause my problem but I bet it's the culprit.
I replaced the hose that was leaking and put in the new alternator this morning. I'm still having the same problem. Anyone got any ideas? Dash lights still do not work. But the charge light and 4wd light are still on and the head lights work highs and lows. I might pull the starter out and get it tested.
I had the starter tested and it checked out OK.
Toyrunnerns: I will admit I have been forgetting to disconnect the battery while I'm trouble shooting things. At this point I'm just gonna have to figure out were the wire or loose connection is.
First step is to see if you are getting power to the starter solenoid:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
I hooked those to wires up to the other side of the fuse that connects to the alternator wire and it now works but I'm not sure what the wires are or were they are supposed to go to. Here are some pictures or were the end up in the fuse block under the hood.
This wire ends at the AM1 40amp fuse
This wire ends at the black plug in the fuse black plug in the fuse block
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
jmc88runner
Jun 18, 2015 03:39 PM
