Sponsored by: CARiD
I need 4.88 gears for my 1997 4Runner 2WD
Old Nov 10, 2010 | 04:31 AM
traxxi2003's Avatar
I need 4.88 gears for my 1997 4Runner 2WD. What is the cheapest and easiest way to do this? I know i could get a new third member with new gears, but that will cost at least $600.00 or more. Is there any other way to do this? Did Toyota ever offered a factory 4.88 rear end that will be a direct fit on my truck? Thanks!!
Old Nov 10, 2010 | 08:59 AM
brian2sun's Avatar
Gears are expensive, no way around that. Finding a factory 4.88 diff will be very hard as they are the rarest of all. You can get a ring and pinion for ~$150 and a master bearing kit is ~$175-200. So with tax and or shipping, you're looking at $350-400 in parts so $600 installed is a good price.
Old Nov 10, 2010 | 09:25 AM
89minimonster's Avatar
check out ebay. i just ordered mine for an 89 pickup from justdifferentials. came with master install kit and nittro gear r&p for 320 shipped
im sure you can find better deals somewhere, if youo can do the install yourself if not then a third member would come out cheaper around here.
Old Nov 11, 2010 | 12:14 PM
rattlewagon's Avatar
Why do you need 4.88s? 4.56s are alot easier to find in junkyards.
Old Nov 11, 2010 | 06:53 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
IDK about a 2WD T100, but I know for a fact an 8" from a Mini won't... WILL NOT bolt into a 4WD T100.
My 4WD T had 4:87's factory.
wouldn't pull a flea off a dogs back, but had 4:87's... And god do I miss that truck.
Only needed a 4.3
Old Dec 8, 2010 | 02:44 AM
traxxi2003's Avatar
Sorry it took me this long to reply to your question, I'm going with 4.88 because I will be running 33x12.5x15. I think 4.88 will give my truck back the factory power and maybe a little more. Thanks!!
Old Dec 24, 2010 | 02:03 AM
dirtymotoman's Avatar
browse a few pick your parts, youd be surprised at all the diamonds in the rough
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
