Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
T100 Radio Problems
Old Nov 2, 2010 | 08:45 PM
zasuttles's Avatar
T100 Radio Problems
I tried to put my radio in my truck yesterday but it turned out to be a waste of time. I wired everything up and hit the switch. Nothing happened. So I unhooked just the ground and hot and straightwired them to the battery. The test light still said I wasnt getting any power. All fuses are good and the radio just came back from Pioneer checking out all good. The same thing happened with the stock radio but I thought it was just the radio. Any ideas why it would just not work like that?
Old Nov 4, 2010 | 01:29 PM
drpdmazda's Avatar
are you getting 12volts at both the switched and constant leads? also are you testing on both sides of the plug? i have seen some plugs where they will get voltage on one side but not the other. and are you getting 12volts constant and switched from the vehicle? if you have the yellow and red twisted together and tap them to the battery positive then the black ground to the battery ground, does the radio power up?
Old Nov 5, 2010 | 05:16 AM
zasuttles's Avatar
I reran all my wires last and put my memory and hot together with a wire nut along with an extra wire and ran it to a toggle switch. Then I ran the switch to the battery and it came on. So today I'm gonna try to leave the hot on the toggle and run my memory straight to the batter to see if it still works so I can pick back up without the radio resetting everytime. Thanks for the help
Old Nov 5, 2010 | 01:44 PM
drpdmazda's Avatar
you should be able to get constant as well as switched from the steering column, or the fuse box, i would try to avoid any sort of toggle switch just incase you forget to turn it off or something, nothing worse than coming out for work and finding your battery dead. you more than likely have a blown fuse and dont realise it. not too farmiliar with the t100 but some yotas have a fuse for the radio under the dash and or under the hood. does your dome light work?
Old Nov 5, 2010 | 01:48 PM
zasuttles's Avatar
It may but I'm not sure it doesn't have a bulb in it so when I get one I'll tell you for sure. I've had everything but my guage cluster tore down and I never saw a fuse there. Any idea where it might be under the hood?
jasonty
41
Dec 23, 2018 01:00 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jgwerth
Jul 16, 2015 03:23 PM
taller1
Jul 16, 2015 03:00 PM
mtb_taco
Jul 15, 2015 08:36 AM
